Opinion on a wet shot?
Hey guys, I been wanting to spray a 50 wet shot.
I have a 2010 5.3 on 14 lbs with e85, boost cam and a 36k converter, What are ya opinions on spraying a 50 wet shot down the track?
Truck Sponsor
Does more for you down low. If you have traction.
So down low drops et increase mph some.
Up top. Will increase mph but et will not drop as much as if you hit it down low.
also 50hp might not do much as you think in the scheme of things.
Say a truck makes 250 to the ground. At 50 shot you will feel that pretty good bump percentage in hp.
Now if you are making 600 to the ground. That same 50shot will feel weak and might not feel it at all.
You could get the 50hp by upping the boost 2-3 psi unless, as said, you want to lower your 1.6ft and combat lag at low end. Cost wise, you could get the 50hp cheaper by increasing the boost, if your setup can handle it. Your tune will tell.
