NOOB wastegate question
Old 10-01-2015, 12:25 AM
LSX-81-SIERRA's Avatar
Default NOOB wastegate question
Is a 46mm wastegate with a 10psi spring a good match for an s475 83mm 1.1 AR T6 on a stock head and cam lq9? I read on turbosmarts webpage, big turbo + low boost needs a big gate but it doesn't specify just how big the gate needs to be. The gate will be placed directly under the turbo exhaust flange. I will be using Tricks Twin Scroll T6 manifold.
Old 10-01-2015, 12:35 AM
Restricted
JordanH's Avatar
It's plenty big enough to control boost... Even around 7-10psi range
Old 10-01-2015, 11:18 PM
fctry286's Avatar
Check out Synapse engineering they design the best blow off/by pass valve on the market truly. they are all tested to 200psi of boost pressure with zero leaks. it is what I run on my truck. Synapse Engineering | Official Page for Blow Off Valve, Wastegates, Intake
Old 10-02-2015, 07:05 AM
I have a gauge for that
Atomic's Avatar
I would personally use a 50mm gate but 46mm gate should be fine.
blownss27
08-14-2020 08:27 AM
Justin87gn
09-10-2015 12:06 PM
Cowboy Tom
09-05-2015 04:29 PM
Alco
09-04-2015 04:08 PM
SWINGRRRR
09-03-2015 07:49 PM
Quick Reply: NOOB wastegate question
