LSA supercharger on a 2005 RST truck write-up
Old 11-27-2015, 01:58 PM
  #41
2 SSlow's Avatar
Originally Posted by SUTTERERMAN85
I'm running a dod cam from comp with my lsa blower. Just have the dod turned off.
Do you have pics of your setup? Did you encounter any hurdles while doing the swap on your Tahoe?
Old 12-11-2015, 05:31 PM
  #42
Registered User
Tucker12's Avatar
Default LS adapter plates
I have a brand new set of LS adapter plates that have never been installed. Converts cathedral port heads to rectangular port. I was going to use them on my LS1 with LSA supercharger but decided to go with an LS3 instead.
I any one is interested please let me know.
Jim
Old 12-11-2015, 08:51 PM
  #43
superbee's Avatar
pm me a price
Old 12-12-2015, 06:53 AM
  #44
Registered User
Tucker12's Avatar
Default adapter plates
Originally Posted by superbee
pm me a price
$100.00 plus shipping
Old 12-12-2015, 06:00 PM
  #45
treylittlefield's Avatar
Jim
How much?
Old 12-12-2015, 06:59 PM
  #46
Registered User
Tucker12's Avatar
Old 12-17-2015, 03:45 PM
  #47
embs2001's Avatar
[/QUOTE] The stock bypass valve setup uses an electronic solenoid to control it. I tried simply deleting the valve and hooking it back up normal and it would not make any boost, i had to reverse the tubes and it worked fine after that. My crude $45 boost gauge is tapped into there for now. There is adjustment in the mounting bracket! you need to adjust it so that it will be fully closed at rest so there will not be an air leak on the internal valve or you will not make boost!
Size:  208.5 KB[/QUOTE]
Im looking at how you have your bypass valve setup and I noticed I did mine different. I have the bottom port capped and the top port going to the vacuum. I get 8-9 lbs of boost on a 5.3 with stock pulley at WOT but i'm wondering if my part throttle boost is a little low. Is that picture still how yours is set up?
Old 12-19-2015, 08:05 AM
  #48
SUTTERERMAN85's Avatar
8-9lbs is correct for a stock pulley. Yours is working correctly. I'm at about 10.5lbs with a 2.85. I was 8.5lbs on my 5.3l with a baby cam and all stock exhaust.
Old 12-19-2015, 09:46 AM
  #49
embs2001's Avatar
Yea, i just wonder if I hook the lower port up to the boost side I might see more part throttle boost. Right now I have the bottom one capped.
Old 12-19-2015, 07:50 PM
  #50
Alco's Avatar
do you guys use the stock truck crank pulley ? what kit do you buy to make it work it's not clear on the lssimple.com what I need to buy !??
Quick Reply: LSA supercharger on a 2005 RST truck write-up
