LS Power!! Twin 76mm Turbo 4.8L 1200HP & still going!!
#161
The rod ratio for the 4.8L is perfect for boost. The High RPM and High Boosted Torque translates into serious HP.
Well, I still think its true... Here's a quote taken from another forum on a stock bottom end turbo 5.3:
Skinnies 8.68 - YouTube
Oh and Skinnies RX7 made 855rwhp/1145rwtq on 24lbs. It's a single billet Precison 78mm, bone stock bottom including rod bolts, ring gap, and oil pump, GT2-3 cam, springs, and pushrods. That's through a glide, a 9", and some massively heavy 33" x ?20"? x 15 wheels with DOT street tires. Easily over 1000bhp.
These motors are plain sickness. It makes me laugh when I see a multi thousand dollar engine running 11s/12s/13s etc (been there, LOL).
#163
#164
#165
283 crank in a 327 = 301... shift that bitch at 8k
on the subject of this motor though. there was information released. it was put up on the bullet. apparently the owner of the shop of where it was dynod at is VERY good with building motors. ill have to see if i can find the link
edit:
here it is http://www.yellowbullet.com/forum/sh...ghlight=1200hp
edit:
#166
edit:
here it is 1200hp from 4.8 stockblock: fiction or reality? - Yellow Bullet Forums
edit:
#169
Exactly! Just think if they took a few seconds and spec'd out a good cam. You can find a lot of power with the right combo. (not that they needed anymore)
Excellent write up thanks for sharing!
Was there a dyno graph by chance, I'd really like to see the TQ numbers and what rpm ranges they were working in. I'd like to see how much the shorter stroke would have on the low rpm torque production. I'm not a huge fan of high stalls, not what I'd like to drive daily.
Thanks again!
Thanks again!
