boost and heads
Old 12-25-2012, 10:03 AM
02chevyls1's Avatar
Default boost and heads
im going to be putting togeater a boosted 370 and am wondering how important it is to get the stock heads p&p or buy aftermarkets or just use the stock 6.0 heads. is there a going to be noticeable difference in the two as far as hp and tq goes ive been told that heads dont hake much difference on boosted apps also is there any aftermarket high valume oil pumps on the market.
Old 12-25-2012, 10:24 AM
11 sec. Truck Mod
TIM Z's Avatar
How much boost are you planning on running?
Old 12-25-2012, 11:50 AM
ZO6Ted's Avatar
Depends on the boost setup and the psi. Blowers like heads, turbos don't care all that much. Its always a plus though.
Old 12-25-2012, 12:16 PM
Registered User
turbo-ls7's Avatar
Your pushing air threw it but you got to make sure Ur value springs and load is righ or eles can cause value float and beat Ur value train up been their done that
Old 12-25-2012, 03:20 PM
Laid Back
Beatdown Z's Avatar
Ported heads = more power with less boost
If you have the money, go for it.
Old 12-25-2012, 03:34 PM
chevyboy.520's Avatar
P&P heads will have less restriction, which will flow more air. Which will make more power with less boost and ever more power at same boost less once you turn up the boost. If you can get PP heads do it.
Old 12-25-2012, 07:47 PM
lglowe's Avatar
If you can get a good set of heads that make 50 hp na then that'll be around a 100 hp gain around 15 psi boost. That's a nice upgrade
Old 12-25-2012, 08:08 PM
Registered User
turbo-ls7's Avatar
Which ever works for you and fits Ur budget go for it
Old 12-26-2012, 03:42 PM
02chevyls1's Avatar
I'm running a 76mm turbo and planning on 15 lbs of boost
Old 12-26-2012, 06:11 PM
I have a gauge for that
Atomic's Avatar
Get the best heads you can afford.
Quick Reply: boost and heads
