Find my weak link
formery SilverSleeper1500 (12-06-2011)
Find my weak link
Hey guys it's been a while since I've been on here haven't been working on the truck much have been pretty busy traveling for work the last 2 years, I see I've missed a lot of cool ****!!! Nice going on everyone's builds! I remeber when we were all just starting to figure out how nitrous worked lol
Anyways getting back to my truck build and I'm going to change a couple things because we all need MORE POWER!!!
With that being said I was wondering if you guys could tell me what possible weak links you see with my setup my truck is pretty cave man now but it's not my DD anymore so I can fully devote some quality build time now. With that being said here is the truck as it sits currently and the build thread.
https://www.performancetrucks.net/forums/projects-gallery-189/06-ecsb-rear-mount-build-515259/
Engine:
5.3L
Thunder racing 220 cam
Chromeoly push rods
Patriot dual valve Springs
Titanium retainers
Edelbrock Super Vic intake manifold
60 lb bosch injectors
90mm TB
Stock heads and bottom end
Drive train:
4l80e stage 5
Circle D 3000 stall
3.73 gears (stock)
2 piece drive Shaft (stock)
Tru cool 40k
Turbo
Rear mount Master power 70mm
Tial wastegate 9 psi spring
Tial BOV
Alky Control methanol injection single nozzle
The truck seems slightly sluggish some times, it ran a 14.2 at 98 on 9lbs it weights 5280 with me in it (155lbs) and full of fuel I was expecting a little more seems mucho slow to me.
My Current goal is to get this truck to the low 12s maybe even 11.99
First thing I'm doing is going front mount with Tricks manifold and crossover I currently have a BW 75mm fresh in the box never used (don't know all the specs it's in my shop up north will get later) is this the best option or what would be a good turbo for my setup
So gentleman what are your thoughts????
Engine:
5.3L
Chromeoly push rods
Titanium retainers
90mm TB
Drive train:
4l80e stage 5
Circle D 3000 stall
3.73 gears (stock)
Tru cool 40k
Turbo
Tial BOV
Find a TBSS cathedral port manifold and your 90mm will work and they make great power for a factory intake. What AFR and timing are you running at 9psi? Those times seem off, your mph isn't high so it's not that it is just struggling off the bottom. Is the tune really conservative?
With running a 60/30 mix turned half way up on the selector it runs around 11.2 I belive
Tune, intake, gears unless you're running a really short tire. Truck just isn't making any power for your setup and you should be leaving on full boost if you're not. Iirc my 07 weighed 5050 with me.
