Finally gathering parts for my 5.3l Turbo build
Hey guys I have a 2002 silverado RCSB.
I ordered a trick performance hot side manifold kit with down pipe, and i bought a Turbonetics TC76 turbo off a fellow member here. which i believe is a s 68/76 turbo.
Here is what I'm thinking as the rest of my build here.
ls6 cam
Trick performance intercooler kit
38mm waste gate
yellow valve springs
60lb injectors
340lph fuel pump
I'm planning on somewhat daily driving the truck and i plan on running 12 psi of boost on 91 octane with no water meth.
Is this doable and reliable?
I also have a set of stock 243 heads off my gto that I was thinking about throwing on the 5.3l block because I heard it will lower the compression? Would this be a good idea to do with a set of ls9 gaskets and head studs?
ls6 cam
38mm waste gate
60lb injectors
340lph fuel pump
Formerly ScreamingL
ls6 cam
38mm waste gate
60lb injectors
340lph fuel pump
ls6 cam
38mm waste gate
60lb injectors
340lph fuel pump
as for the 243s they will drop the CR to about 9.0 on the 5.3, i had this setup a few years back...is it needed? no will it help? yes
Ls9 gaskets will work for ya, Head studs for sure
you can run 12psi on 91 octane just need to have a tuner realize its 91 and gives ya a safe tune. dropping the CR with the 243s will also give you a larger safety margin for 91octane
also if the heads are from a ls2 GTO then the springs should be yellow already
5.3lSilverado
25
08-29-2016 12:48 AM
