Does your turbo spin at idle?
#31
I guess if your turbo isn't spinning at idle you could be a non-boost condition. I would imagine the TB blades closed about 95% at idle would make the boost guage show vacuum even if the turbo is pressurizing the cold side so if you build a kit without a BOV/BPV, are you always under boost in the cold side piping?
It seems like a majority it turbo kits run the standard Tial BOV. Are those kits letting unfiltered air into their engines on a regular basis?
Sorry OP for getting off-topic...
RB
RB
#32
Makes sense. Thanks for the info.
Just wondering. Would a turbo kit be more efficient with a BPV (open under cruise) that allows the compressor to freewheel reducing the load (like the OEM turbo cars)? I would imagine another benefit would be that the freewheeling turbo would be spinning faster than a turbo under load so it will transition into boost more quickly. Make sense?
Rick
Rick
#33
Correct spring pressure and correct vacume line size is key to control the surge.
"Version 1" Tial BOV:
-22 to -23 in/Hg use Pink - 11 Psi spring
-18 to -21 in/Hg use Un-painted -10 Psi spring
-14 to -17 in/Hg use White -8 Psi spring
-10 to -13 in/Hg use Black -6 Psi spring
"Version 2" Tial Q BOV:
-22 to -23 in/Hg use -12 Psi spring (not available)
-20 to -21 in/Hg use Pink -11 Psi spring
-16 to -19 in/Hg use Un-painted -10 Psi spring
-12 to -15 in/Hg use White -8 Psi spring
-8 to -11 in/Hg use Black -6 Psi spring
0 to -7 in/HG (or supercharger) use 3 PSI Spring (Pink)
I got this info from: http://www.extremepsi.com/store/cust...me.php?cat=390
#34
Rick that load you speak of is being supported from exhaust energy your engine is creating anyways. As that load increases on the turbine, so does the airflow generated by the compressor going into the engine. Why would you want to vent that "freely" generated air and have to apply more throttle and engine RPM just to get that same air flow back?
#36
See post 28-30. I'm pretty confident I'm not pulling any unfiltered ait through my BPV. I used the same Vortech Race BPV on my Procharger kit. I used an old radiator hose and ran it from BPV throught the fenderwell up to a piece of 1" PVC pipe that reached the driver's window. I drove the truck around my neighborhood at various throttle positions and speeds and I always felt presurized air till the vacuum dropped enough for the BPV to close for boost. One of these days I'll have to tap the cold side before the TB for a boost/vacuum gauge and and see how pressurized it is.
Rick
#37
Rick your not any where near creating "pressurized" air at cruise, hint the -10 or more vacume you see on your gauge. That turbine wheel is already freewheeling, as the engines naturally aspirated air demands are greater then the compressor flow at those low shaftspeeds.
BOV's perform better in "Performance" turbo vehicles, the R&D is supported by the largest names in the game. Go buy "turbo magazine" and go cover to cover and see how many BPV's remain. Mitsubishi ,Nissan, Toyota, and even our beloved GM camp with APS's $14,000 turbo kit for the C6/z06, use BOV's. The SRT guys remove them to get the sounds, the STI and EVO guys remove them because they leak, all being replaced with a BOV.
OEM turbocharged vehicles have a BPV to help with fuel mileage and wear because they have small turbochargers, where a blimp of the throttle brings boost instantly, resulting in more air/fuel/power, resulting in bad fuel mileage and more wear. Also the noise in not something every one wants to hear. Also, some cars don't have previsions for a vent type system, either engine management or engine bay layout.
Bottom line, BPV have there place on belt driven chargers and OEM cars, like a volkswagen bug taking a lady to work.
05GMC4.8
08-07-2015 09:55 PM
lxcoupe
07-27-2015 08:19 PM
GMCtrk
07-17-2015 06:39 PM
