Direct port water meth injection
I have been thinking about skipping the air to air intercooler and going with a direct port water meth injection system to cool things down.
I was wondering if anyone had any experience with this set up.
Intercooler or not I just want to know how they preform.
I would also consider straight methonal injection if that would provide better cooling effects.
And yes I am aware of all the potential issues/ dangers of relying on this system!
Direct port scares me... There is very little consistency in nozzles compared to an injector. That coupled with a larger opportunity for inconsistent pressure or flow and I think its a recipe for disaster. Not to mention you would need solenoids to keep it from sucking in meth when you're in vacuum. I think with the tools and kits we are playing with meth is best left as a pre throttle body fuel.
Yeah so I was thinking about making a full blow fuel system for the meth supply.
Ie dual pumps filters and boost ref regulator. Not sure if that has been done but it was what I was thinking. I assumed the noids would be needed as they come with most kits.
But the consistency of the Nozzels is something I did not consider. That is something to worry about. No way around this with higher quality units?
I have a gauge for that
It depends how much meth you want to spray and how much of the total fueling you want the meth to do. I have a spray bar setup on my truck and use methanol as the boost fuel with my nitrous. I dont think its worth all the trouble if I just wanted meth alone. I had a 14gph nozzle pre-rotors before and it held temps pretty stable. With the spray bar setup spraying a 150hp shot the intake temps dropped about 45 degrees between the start of the 1/8th and end of the 1/8th.
If that was the case then cars to run straight methanol wouldnt be able to run the amount of timing they do, and no intercooler if no cooling effect was present cause evaporation would still occurr imo.
same principle on why you use a plate or shark nozzle up to a certain point, but a direct port for big pill shots and for a much more consistant supply of n2p/fuel mixture
