Boost compression
Old 02-09-2021, 11:46 AM
smityinms's Avatar
Default Boost compression
I got a set of custom 6.0 ls diamond pistons with a block I got awhile back. If I did the compression calculator right should be around 8.8-8.9 with 60cc heads. I have set of 243’s that are 60cc. Question is that too low for a turbo truck. I have two two turbos, 76mm and a s480. It will be a street/strip truck with Holley termx. I attached the piston specs, thanks
Old 02-09-2021, 12:01 PM
arthursc2's Avatar
Received 1,433 Likes on 1,061 Posts
Whats your power goal and what fuel do you intend to run it on most of the time?
Old 02-09-2021, 12:23 PM
smityinms's Avatar
Pump gas if possible, truck already has 4l80 with 3600 circle d, horsepower I guess be limited to to the fuel, I like to see 600+.
Old 02-09-2021, 12:30 PM
ALL ULL C's Avatar
Pump 91, 93, or E85?
That low of compression should allow some tuning forgiveness and maybe a little more PSI on your typical 91/93.
Old 02-09-2021, 12:37 PM
smityinms's Avatar
I got access to 93 and got e85 for another project I’m working on. Just curious if they worth putting in a 6.0 with rods.
Old 02-09-2021, 01:27 PM
arthursc2's Avatar
With enough boost and crank case venting you will hit your 600
smityinms (02-09-2021)
Old 02-09-2021, 02:05 PM
ZO6Ted's Avatar
While 9.5 would give more out of boost torque and drivability 8.8-8.9 will allow you to crank it up more on pump 93. Ultimately more boost = more power. If that's your goal just run it! If you want more compression though use some 706's instead but you'll have to run less boost, timing etc or more octane via meth or E.
6.0l RST
12-15-2013 09:14 PM
dirt track racer 81
06-02-2008 08:35 PM
mcfarlnd
11-15-2007 05:30 PM
Black-Syde
06-03-2006 01:20 PM
OLD BULL
05-02-2006 06:45 PM
Quick Reply: Boost compression
