Blem manifolds for sale.
We have a couple of
T4 and t6 blem manifolds on the shelf.
If you are on budget and wanting to build your own kit.
Or
You need/want to cut the manifold to fit your project
Or installing a vband flange these blems are perfect for that.
These go pretty quick.
Turbo-Manifold
Or
Turbo-Manifold
Do you have any pictures of someone cutting off the 2 bolt flange and welding in a 44mm v-band for a Tial? I have one of your manifolds and was going to run an adapter but this sounds much better. Any problems with it cracking? I'm assuming it needs to be tig welded correct?
Thanks!
Thanks!
Thanks!
Thanks!
What cracking?
Sorry, cracking as in welding a new vband flange in place of the 2 bolt and having the weld crack... not the manifold itself. Do you know what alloy the manifolds are? Just want to make sure i use the right filler rod if I do decide to machine it off and weld on a vband.
Can use 308 with good results.
Haven't had any one call with welding a flange on the t6 manifolds.
