99 Z71 turbo build list reviews needed
Update with changes, I've decided it would be better to just do all this work to my nice rust free blue 04 ECSB instead, it just seems easier and more realistic.
So on to the list,
Fuel:
Twin Walbro 450 F90000274 fuel pumps
FIC 1000cc injectors
Aeromotive A1000 13101 FPR
-8 feed and -6 return
Flex fuel sensor
Turbo:
VS racing or ON3 billet 7875
Trick performance T4 manifold
Custom 4 inch down pipe (if I can fit it)
Treadstone intercooler
JGS 400R wastegate
JGS 500 BOV
Turbosmart eboost2 controller
Exhaust:
Custom 4" dumped before axle
Carven R series muffler
Trans:
4L80E swap
HD2 shift kit
Jakes stage 2 rebuild
TruCool 40k cooler
PI triple disc converter
Transfer Case:
Np246 autotrac
Merchant auto pump rub kit
32 spline input
Engine:
SBE 04 5.3 regapped rings
Stock heads maybe slight hand port
Tick stage 1 turbo cam
LS9 gaskets
Misc:
Braided hose for fuel, oil, trans fluid and other
4 vibrant HD 3" clamps 12516
Rear end:
10 bolt
3:73 gears
Detroit tru track
1350 yoke
Rims & Tires:
20" GM all terrain style rims OEM or reps
33-12.50-20 ridge grapplers
BORA 2" spacers
Suspension:
6" diff drop lift dropped down to level angles
4" (possibly 6"? Not going for height just leveling it with the smallest block possible) lift Deaver F87 leafs with factory block removed (fox or bilstein 5100 shocks)
Traction bars?
Atomic coilover brackets
QA1 promastar double adjustable coilovers
Moog parts everywhere possible
Hellwig front and rear sway bars (nothing crazy will be unhooked when offroad just want them for less body roll on the street)
Steering:
PPE tie rod sleeves
Cognito pitman and idler arm support
Moog parts everywhere possible here too
Body:
Color matched bumper cover
Debadge and demold
Esky handles
(Undecided on 06 front end swap)
Lighting:
Opt7 LED heads, tails, and fogs
Switchback Markers eliminate DRL
Cleared heads
Fleece all lights mod
Interior:
Pioneer DEH80-PRS (would like touch screen car play but undecided)
Stock premium Bose until it blows
Escalade cluster
As many Denali or escalade trim pieces as I can find
PCM/Tuning:
E38 computer
Flex fuel OS
Segment swap for the 80e
Tuned with HPTuners (by me depending on how well I do fine tuning might be done by professional this is my first time trying)
2.5 bar MAP sensor
GM IAT sensor
Driveshafts:
2500 front shaft
Custom rear 1350 joints both ends (steel or aluminum?)
Let me know if you see something that could be changed to save money or something that could be changed to stop the headache of junk parts
So on to the list,
Fuel:
Flex fuel sensor
Turbo:
JGS 400R wastegate
JGS 500 BOV
Exhaust:
Trans:
4L80E swap
HD2 shift kit
TruCool 40k cooler
Transfer Case:
Np246 autotrac
32 spline input
Engine:
LS9 gaskets
Misc:
Rear end:
10 bolt
3:73 gears
Detroit tru track
1350 yoke
Rims & Tires:
BORA 2" spacers
Suspension:
Traction bars?
Steering:
PPE tie rod sleeves
Body:
Debadge and demold
Esky handles
Lighting:
Cleared heads
Interior:
Escalade cluster
PCM/Tuning:
E38 computer
Flex fuel OS
2.5 bar MAP sensor
GM IAT sensor
Driveshafts:
2500 front shaft
Well the 99 is 100's of lbs lighter but it's not like your going to be short on power. Looks like fun either way!
