LQ4 boost ?
Old 06-16-2012, 07:33 PM
sharpshooter's Avatar
Default LQ4 boost ?
After seeing some 5.3 and 4.8 live with 18-22 psi of boost, what can a stock LQ4 be run up to using 93 and 50/50 water-meth?
more than once
Old 06-16-2012, 07:52 PM
11 sec. Truck Mod
TIM Z's Avatar
Yes, I have ridden in a newer GTO that blew up the first engine, then was replaced with a 100,000 mile junkyard LQ4, cam and front mount turbo that TJ tuned, It was at roughly 20 psi and kicking ***
The limit is the rods, the first engine bent the rods, but didnt hurt the pistons, its all in the tune for the most part.
That car runs 9.70's IIRC @ over 140mph.
BTW i see roughly 13 psi / spikes of 14, no issues.
You gonna turn up the boost?
slowec's Avatar
My cam only lq4 saw 12.9 psi with no meth in 80 degree heat. (no KR) I am adding straight meth and shooting for 15 psi on low timing. 10's or BUST
Old 06-17-2012, 01:39 PM
Red Truck's Avatar
My stock lq4 butted the rings together on number 7 at 18lbs on 91 octane, 11 degrees of timing. Intake air temps were 118ish, no water meth. Engine had 100k miles and crazy amounts of nitrous put thru it before the turbo.
Now I am at 9 degrees timing with some 101 mixed in and 2 steps colder plug and timing mark on number 7 looks perfect. So may have rattled it just enough to butt the rings up. Be VERY careful with timing. Mine did this and had absolutely no knock retard.
Old 06-17-2012, 01:52 PM
Mod with training wheels
smokeshow's Avatar
Pushed 16-17psi through mine repeatedly last night. I re-gapped the top rings though... And its an L76.
Old 06-17-2012, 01:59 PM
Baltimore Whore
Mangled03gmc's Avatar
18 psi should be ok given your tune/ timing/ fuel is right on the money
Old 06-17-2012, 04:21 PM
la blue's Avatar
how much did you gap the top rings?
Old 06-17-2012, 04:40 PM
smokeshow's Avatar
.024"
Old 06-17-2012, 08:33 PM
Laid Back
Beatdown Z's Avatar
Getting used to the power, huh?
Old 06-17-2012, 08:40 PM
skeet's Avatar
isnt it the 03's that have the weak rods? i have an 05 lq4 im putting in the s10 with a PT88 more then likely, good post now i know some boost levels to try and achieve lol
Quick Reply: LQ4 boost ?
