5.3 s366 to small?
Old 02-26-2017, 02:38 PM
Registered User
BoostinJonnyukon's Avatar
Default 5.3 s366 to small?
So I've been recommended this combo for my 5.3 build in my Yukon.
Turbo BORG WARNER S366 S300SX3 S300 66/73 17728
Cam 212/218 .553/.553 113+2 lil john stage 2 truck cam
On unmilled 243/799's
Gen4 truck intake 92mm tb
80 deka injectors
340l pump
Pistons r lil johns 5.3 boost flat top wiesco pistons
Rods Callie's compstar h beam rods
Stock crank.
Trick turbo's 88-98 turbo log and down pipe.
Not sure on a2a cooler yet.
I'm looking for 500bhp and maybe Alil growing room I guess
I want to be able to tow a decent 5k trailer so the wife I can travel
And be reliable rain snow and scorching sun and live 100k.
Are there any other weak points in the gen3 motor besides the piston n rods?
Melling high volume pump of course.
Attached Thumbnails 5.3 s366 to small?-img_0064.jpg   5.3 s366 to small?-img_0017.jpg
Old 02-26-2017, 04:12 PM
FFDP's Avatar
I don't see why that wouldn't work for your power goals.
Old 02-26-2017, 04:24 PM
Registered User
Should a stock crank live or should I really think about a crank and don't be afraid to turn it up Alil? Lol
Old 02-26-2017, 04:39 PM
03sierraslt's Avatar
Stock crank should be just fine. Just make sure it's balanced for the new rods and pistons.
Old 02-26-2017, 04:47 PM
Registered User
Yup clean up checked n balanced.
Old 02-27-2017, 09:31 AM
That will be just fine for that goal.
Old 02-28-2017, 07:14 AM
Registered User
Thanks guys! what boost pressures do you think I'll see? I will be lucky to find true 93 around me but mainly 91 octane is 3 mins from my place.
Old 02-28-2017, 09:25 AM
kbracing96's Avatar
I've got a s366 on a 5.3 in my 69 c10. It's a great little turbo on that motor. Spool is so quick, makes for a very fun truck! Currently running about 9lbs on it.
The following 2 users liked this post by kbracing96:
BoostinJonnyukon (03-01-2017), crashmymax (03-18-2017)
Old 02-28-2017, 10:07 AM
Registered User
Nice what's done to the motor and any dyno time?
Old 02-28-2017, 04:19 PM
fastjweb's Avatar
I have one on a 4.8 at 16-17lbs and doesn't seem to be falling off yet. probably around 630-640 rwhp. just ran 10.84 and best trap of 124.69 at 4200lbs, 13.5 degree of timing and 10.2 afr. 93 pump, and single nozzle 50/50 meth. I will also add that's with trick stg 2 kit with standard 3" intercooler and 3" intercooler pipes.
