2014+ Boost Level
The 5.3 should have plenty of nut before you need to swap to the 6.2.
Without some sort of track run or dyno pull its hard for us to help you here. I have all the confidence in the world you would be able to put that truck in the 10's with that blower on that engine with the right mods around it.
Hahaa... funny story I have to tell about coming home today after work! Ok it's raining alot here in Central Ms. today and you guys see that I have been bitchin about my power level not being enough since the blower install. Well I couldn't hardly make it home today with wet streets, blower, converter, even the 3.08 gears didn't help much. This ****** spun at every light and cars behind me were flashing there lights, blowing horns and passing me as I was sitting still! Wild **** here guys! Yeah I had to put the 3.08's back in because the 9.76 w/3.73's started howling for no reason and it's a real snail now.
RT
RT
RT
RT
That L86 would be in my truck in a few days if I had one lol!
Yes and run mid 11s with ease! More if you want.
Well Boyz... I just bought a used 53 mile LT-1 High side pump for $100 shipped. Sooo Injectors are next and then 10+ psi boost and Dyno in the spring. I'm having to buy in small purchases so the wife doesn't get irate + Christmas shopping and a 17 year old daughter! Geez.... BTW as far as Dyno and street tuning who nows there **** on these Gen V motors?
RT
RT
Yeah I have talked to a couple of guys about it and both said it could go either way... might bump up or might lay flat. With the compression these motors have and boosted one would think it would pick up a bit but I don't know **** from **** so that's why i'm asking. Somebody had ARH build them a set of 2"ers and it did bump power upper area and didn't kill low or mid either, that was a couple years ago and haven't seen any update on that build. Haha and can't remeber where saw it to be honest.
RT
RT
RT
RT
From what I've heard if you had to do it by email New Era Performance in NY is probably as good as it gets on '14 and up.
