2000 Silverado vortec 5.3 PCM wiring diagram? - PerformanceTrucks.net Forums
Thread Tools Search this Thread
Old 04-19-2006, 08:27 PM   #1
digital's Avatar
Question 2000 Silverado vortec 5.3 PCM wiring diagram?
I have the older style Whipple Supercharger that used the "piggy-back" Whipple computer. I removed the Whipple electronics and now have a Nelson tune.
I have just had both knock sensors professionally replaced.
I am still throwing the code "Knock sensor low voltage".
Is there anywhere that you know of where the Whipple computer spliced into any wire that could affect the knock sensor wire voltage?
Any help is greatly appreciated.
Thanks,
Digital
digital is offline   Reply With Quote
Old 04-19-2006, 08:57 PM   #2
Moderately Differentiated
dewmanshu's Avatar
I know nothing about the whipple and the old piggy back. But here is the schematic for the knock sensors. I highly doubt th epiggy system tapped into them...nevermind, I don't know. I know a guy that had a hummer with the whipple and piggy back pcm...he eventually got a divorce and let her have the hummer. It ran like ****. Codes constantly. She was hatin life. Truck would barely run.
This diagram is for the 2000 chevy silverado 5.3.
dewmanshu is offline   Reply With Quote
Old 04-20-2006, 02:13 PM   #3
digital's Avatar
dewmanshu,
Thanks for the reply, that really helps....
Old 04-24-2006, 03:49 PM   #4
350SS's Avatar
Low voltage referrs to the ground. The knock sensor grounds to the engine block so if they used a sealer that doesn't conduct electricity it could cause a problem... something to check.
350SS is offline   Reply With Quote
Old 04-25-2006, 02:55 PM   #5
digital's Avatar
Hey 350SS,
Thanks for the reply, I'm still trying to figure this thing out.
Do you know where I can find the ground wires on the block for the knock sensors?
I appreciate the help.
Old 04-25-2006, 03:00 PM   #6
High on diesel fumes
thunder550's Avatar
The body of the knock sensor grounds to the block - there are no ground wires specifically for the sensors. That's why he was saying that a non-conductive sealer might be causing the problems - if there is not good metal-to-metal contact between the sensor and the block, it could cause issues. There are several ground straps that connect the engine to the chassis, but I doubt that those could be the problem.
Take an ohmmeter and touch one contact to the engine block (valley cover, if you can) and one to the pin on the knock sensor connector behind the intake manifold. Each knock sensor should read somewhere around 100K ohms. If it is too high or too low you know there is a problem.
I got water down in my knock sensor holes and it corroded one of them. I did the ohmmeter test, front sensor came back at 65K ohms and the rear was at 98K or something. Replaced the front one and all was fixed.
thunder550 is offline   Reply With Quote
Old 04-25-2006, 04:22 PM   #7
dewmanshu's Avatar
yeh good point guys..."professionally replaced"? Did they put wrap or sealer on the threads? Ask them.
Old 04-26-2006, 11:49 PM   #8
digital's Avatar
I talked to the mechanic, no sealer on the threads...he did put the (forgot the name) grease that conducts...
Any how, I guess the next step is to hook up the ohm meter and figure this thing out...thanks for the help..
Thread Thread Starter Forum Replies Last Post
another cam thread steves86ta GM Engine & Exhaust Performance 5 07-28-2015 10:21 AM
Shifting issues after high stall converter install LCHEE GM Drivetrain & Suspension 8 07-22-2015 11:59 PM
air filter box samg430 WTB (Wanted To Buy) 4 07-20-2015 10:12 AM
Need help - Stumble at first cold start, dealer can't find anything wrong Mossyoakglock GMT 900 Trucks General Discussion 0 07-17-2015 08:30 AM
Need input, 350-400hp 5.7l vortec build 4B11T INTERNAL ENGINE MODIFICATIONS 2 07-13-2015 03:48 PM
Tags
2005, 53, chevy, color, diagram, knock, pcm, schematic, senser, sensor, silverado, tune, vortec, wires, wiring
Search this Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
