102/3 Throttle Body for L83/6 motor
Old 07-24-2016, 07:33 PM
KB Silverado's Avatar
Default 102/3 Throttle Body for L83/6 motor
does anyone know of a 102 or 103 TB for the direct injection trucks? I know katech has one but is on back order. does anyone if the nick wiliams or tipis 102 TB's that are being used on LS motors will work not he LT motors?
Old 07-24-2016, 08:06 PM
rjw
rjw's Avatar
Location: Tinker till it blows, then back it off a notch, maybe!!
subscribed ...also interested
not sure about ls/lt, but pinouts on 90mm tb for 6.2 look to be the same as 80mm 5.3
my son's 5.3L 2.9 whipple kit came as a 6.2 kit, so bought a 90mm tb on ebay
tb spacer is different and 4" pulley.
please keep us posted
thx
Old 07-24-2016, 08:58 PM
thx
i just checked and the TB bore on the 5.3 is 87mm.
I've been emailing back and forth with Nick Williams and he thinks his C7 Vette 102 will work on my truck. i will keep this thread updated
Kris
5.3 stock TB is 87mm
Old 07-24-2016, 09:13 PM
07Softail's Avatar
I installed a 6.2 TB on my 5.3 of course I swapped manifolds also.
RT
Old 07-24-2016, 09:27 PM
rjw
rjw's Avatar
Kris
the whipple kit that we received has a checklist. on the 5.3L option , it lists 80mm while on the 6.2L it lists 91mm
this is probably measured at the back (SC) end of the tb. Also, HP tuners stock tune files also reflect those differences
I will only actually see the 2 tb's next week...so, will report back then on actual size and compatibility on my son's 2015 5.3L LTZ
on the attached checklist, you will also see that the silicone reducing hose is 3.5" on 5.3 and 4" on 6.2 (checklist shows 4.125" pulley ??? we received 4.0")
Attached Thumbnails 102/3 Throttle Body for L83/6 motor-whipple-check-list.jpg
Old 07-24-2016, 09:44 PM
rjw
rjw's Avatar
RT
no wiring issues...plug and play on the tb?
did you tune and change tb max area?
thx
Old 07-25-2016, 08:03 PM
07Softail's Avatar
Yes plug and play and tuned... not sure about max area. BB did the tune but I still haven't done a data log after headers.
RT
Old 07-25-2016, 08:37 PM
I see and yes that is confusing, but I measured the bore size and my 15 5.3 LTZ has a 87mm throttle body. I don't dought the 6.2 has a larger one, I'm just sure mine is 87mm. Interested to see what you find when you line them up. Keep us posted
Old 07-25-2016, 09:09 PM
07Softail's Avatar
pretty sure the 5.3 is 80mm and the 6.2 is 87mm measured on the backside of the TB not the front.
RT
Old 07-30-2016, 05:53 AM
rjw
rjw's Avatar
RT
close enough...I now have both....with digital calipers
5.3 is 79.25 w/ 10mm shaft (approx.)
6.2 is 86.75 w/ 12mm shaft (approx.)
Measurements taken at manifold end of tb's
Quick Reply: 102/3 Throttle Body for L83/6 motor
