02-04 LS6 cam in a 5.3 with TVS1900
Old 09-22-2011, 08:45 AM
Import Moderator
beastmode's Avatar
Default 02-04 LS6 cam in a 5.3 with TVS1900
I know most guys recommend the GT2-3 for a blower but being as I have a zo6 cam laying around I was curious as to how this would perform with a TVS. I have heard these things are dynamite with a turbo and figured it would be a good time to do some motor upgrades (timing chain, pump, springs, push rods)
tia
Specs:
2002+ LS6 cam
204/218 int/exh @ 0.05" duration
0.551" / 0.547" int/exh lift
117 LSA
Old 09-22-2011, 09:21 AM
06Sierra2's Avatar
i am curious as well as i have a friend who is a member on here thinking of running a very similar setup.
Old 09-22-2011, 10:27 AM
03sierraslt's Avatar
It wouldnt be my first choice but it would work just fine. Considering you already have it, run it. Depends on what you want out of it Bill. What are your goals?
Old 09-22-2011, 10:43 AM
Import Moderator
beastmode's Avatar
Well my 5.3 has 95k miles on it. I was thinking it might be a good time to do all the upgrades I was saying and while the timing chain cover was off throw in a tiny cam just cause I have it. If the LS6 cam won't make for good gains I probably won't even bother with a cam for awhile.
Anything I could do over 400/400 is icing on the cake for me... but it will be through stock manifolds and stock Y so don't even know if that goal is realistic. I am gonna get a 90mm Edelbrock throttle body but other than that I wanna stick with the supplied injectors.. not sure if they will even be sufficient enough for the LS6 cam.
Old 09-22-2011, 10:52 AM
I imagine the supplied inj are at a min 44lb so they should be fine on a 5.3. Why was i thinking you had a 6.0? I would run the z06 cam over stock, it will help. I see no reason you wont hit 400/400 with stock manifolds etc. 7psi may get you there with the z06 cam.
Old 09-22-2011, 10:54 AM
Import Moderator
beastmode's Avatar
I did have a 6 liter pullout I picked up but traded it for a built 10 bolt because it needed honed and I didn't feel like getting in to that.
Thats what I figured, the LS6 cam should be better than a stock 5.3 cam either way.
Old 09-22-2011, 11:28 AM
carbongmc's Avatar
Im running a LS2 cam, and when it was N/A, it was a very big improvment over stock on the big end. 50 to 80mph it was a totally different truck. You will surely see better numbers with the LS6 cam over the stocker. Even if the kit supplies you with 42lb injectors, that should be plenty for what you want to make. Skipperdaddy made 522rwhp on a much larger cam, but with the 42lb injectors that came with his kit.
Old 09-22-2011, 11:46 AM
Run the z06 cam, ls6 springs. Valvetrain will be quiet and reliable and that cam will pull harder from midrange and up. Plan for tranny upgrades...
Old 09-22-2011, 12:01 PM
Import Moderator
beastmode's Avatar
My thoughts exactly Pat on the LS6 springs and cam... valvetrain will be nice and quiet and stock manifolds will drown out any unwanted engine noise
I am definitely gonna get in touch with Mark and have him go through my 60E (maybe this winter, the TVS set me back a little lol)
Old 09-22-2011, 12:19 PM
My injectors are louder then my Patriot springs.
Quick Reply: 02-04 LS6 cam in a 5.3 with TVS1900
