Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Version 2.0 goes on the dyno today...
Old 09-26-2016, 12:08 PM
Wolftrk99's Avatar
Is he buying you a driveshaft? What were you at when it let go?
Old 09-26-2016, 12:14 PM
Wolftrk99's Avatar
Are they buying you a new driveshaft? What were you at when i blew?
Old 09-26-2016, 12:30 PM
echoman's Avatar
Originally Posted by 86 IROC
The critical speed of a factory driveshaft is 92 MPH IIRC. You figure 4.11s and 31" tall tires in 3rd gear @ redline is 120+ MPH. No bueno...
I better watch out then, as I have the factory driveshaft still.
Old 09-26-2016, 12:36 PM
FFDP's Avatar
This is for Aluminum driveshafts, it's why the speed limiters are 98mph.
Steel driveshafts can stand up to a lot more speed but it wouldn't hurt to high speed balance a steel driveshaft.
Old 09-26-2016, 03:21 PM
10 Second Club
Mine was a steel driveshaft, I would not trust another factory one.
I wasn't anywhere near the truck when it happened. I dropped it off and left, got a call 35-40 minutes later. It made 329 rwhp and 343 TQ before the driveshaft exploded. He said that there is more left in it, it needs more fuel up top still.
Now... what to do for a driveshaft? I have another stock one to put back in it and see if the transmission and rear differential are OK. But I need to get something much stronger and rated for higher speeds. Suggestions?
Old 09-26-2016, 03:33 PM
FFDP's Avatar
A built 3in steel driveshaft will work.
Old 09-26-2016, 04:22 PM
10 Second Club
Any specific vendors that won't charge an arm and a leg? There's a shop semi local to me, they supposedly build shafts for mud trucks and drag cars.
Old 09-26-2016, 04:38 PM
Wolftrk99's Avatar
I asked one of the local ds shops about building me one and they were like just go find one the right length change the yokes balance it and youll be fine... I wont be using them for a driveshaft.... Ever!!! Spring and u bolts, maybe but not for driveshafts!!!
Old 09-26-2016, 05:35 PM
10 Second Club
I called after I posted, they said that they will start with a new tube. Said that they could warranty it up to 1000 HP. I am going to look into it further try to get feedback from people that used them on the local boards.
Old 09-26-2016, 08:47 PM
shupe's Avatar
Driveshaft specialists out of San Antonio set me up right. Great group of folks to deal with and their product is top notch.
Quick Reply: Version 2.0 goes on the dyno today...
