Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Version 2.0 goes on the dyno today...
Old 09-26-2016, 04:40 AM
10 Second Club
Default Version 2.0 goes on the dyno today...
My old setup did 258/281 on a 2nd gear pull with the converter unlocked. It was a 2004 LQ4/80E swapped into a 2000 Silverado that was a 5.3/60E truck. Everything was swapped over from the 5.3 onto the LQ4. Only mods were: Airraid intake tube, TPiS ZL10 camshaft, 8.1L injectors, Magnaflow muffler, tune. Still had manifolds, cats, etc.
Same engine and transmission in my replacement truck now. Things that have changed: EPS cam - 214/220 .604" lift vs. 202/216 .525" lift, both on a 112 LSA. NNBS intake manifold and 92 mm TB. Efans and larger 05'-07' Airraid intake tube. Speed Engineering 1.75" LT headers, no cats, 3.5" exhaust system, Walbro 255 lph pump. My old truck had a factory gov bomb and 3.73s, I installed a Yukon duragrip posi and 4.11s in the current truck. Same heavy 18" wheels and tires.
I am hoping that it picked up around 50 on both HP and TQ. I will post a graph later today once the tune is finished.
Am I being unrealistic?
Old 09-26-2016, 07:08 AM
Wolftrk99's Avatar
My 99 with that xr275hr cam was at 338 with stock manifolds and cats.... So you should be there if not better!!
Old 09-26-2016, 09:16 AM
10 Second Club
If it's close to 300 RW on a 2nd gear pull, I will be pleased. Anything above and beyond that would just be extra.
Old 09-26-2016, 10:22 AM
10 Second Club
Tuner made a 3rd gear pull... driveshaft went boom. I didn't realize that he wasn't making pulls in 2nd or would have stopped him. ::
Old 09-26-2016, 10:41 AM
madmann26's Avatar
Oh damn.
Old 09-26-2016, 11:22 AM
echoman's Avatar
Dang it! However, I'm confused, why would 2nd or 3rd make a difference on the driveshaft letting go? Apologies if this is common knowledge, but I've never heard about it making a difference. Hate to hear anything broke though man, that sucks. Hopefully there is no other damage.
Old 09-26-2016, 11:27 AM
madmann26's Avatar
In 2nd gear, the driveshaft turns less rpm. In 3rd it turns more, much more.
Old 09-26-2016, 11:34 AM
echoman's Avatar
I guess I just thought most/almost all were done in 3rd, automatics anyway.
Old 09-26-2016, 11:36 AM
madmann26's Avatar
2nd gear pulls will normally give you a higher dyno number. That's about the only reason to do it in 2nd gear.
Old 09-26-2016, 12:07 PM
10 Second Club
The critical speed of a factory driveshaft is 92 MPH IIRC. You figure 4.11s and 31" tall tires in 3rd gear @ redline is 120+ MPH. No bueno...
Quick Reply: Version 2.0 goes on the dyno today...
