Torque Build Results
TOTM: January 2007
...I ordered the 2010+ 2.9L Camaro tuner's kit. The Camaro uses the same drive dimensions as our trucks. You have the option of using the Camaro accessories or the truck ones. I use the truck one because I have Hydroboost brakes and modified the pwr steering/alternator bracket so it would rotate slightly towards the driver's side to clear the bypass and dbw TB.
What water pump did you use?
The torque at low rpm is massive despite the 33 inch tires, 4x4 and Dana 60 and being a 6,400 2500 Suburban. If you drove it you would understand that numbers don't tell everything. It's a ten on the buttometer. LOL
I used the 2010+ Camaro pump because the truck pump upper hose interferes with the tensioner. The only downside is that the upper hose is on the inside of the belt. So to do a belt swap, you have to break the cooling system.
I know this is an old thread... but I came across this pic on Tech and I wanted to get more specifics on how you modified your PS and Alt bracket. I see a pretty interesting little bracket for the Alt that I like!
I wonder if you could fit an LS2 TB on there... it would be close.
Here is a current picture of the TB I am running now since I put the engine in my DBW 2003 Suburban:
Home made of course. LOL
Why? I use my truck as an expedition vehicle and can be below sea level in the Imperial Valley or 7,000 ft up in the Sierras. SD would suck.
BTW, I am at 10 lb.s of boost now. Did a run at ZMax and did a 60 ft time of 2.120 with a slow RT of .317. Not bad for getting the Titanic moving.
