Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Made 943HP... But what's best way to load a dynojet?
Old 03-28-2015, 01:18 PM
  #21
Mod with training wheels
smokeshow's Avatar
Originally Posted by blownescalade62
Numbers are always over inflated on a dyno Jet! Been proven many times over! A in ground mustang load bearing dyno is a true dyno.
Do you have some references for this proof that you may provide?
Old 03-28-2015, 02:36 PM
  #22
blownescalade62's Avatar
Originally Posted by George C....
if they are over inflated then explain this....Same car same tune same day....435 rwhp on a MD and 436 on a DJ
dynos were 40 miles apart
Easy the Mustang dyno was not setup correctly.
  #23
Do a google search. Lots of info on it.
Old 03-28-2015, 03:26 PM
  #24
smokeshow's Avatar
Sounds like you have a some belief that the only low numbers are true numbers. This is false. I have searched on Google more than most, and I've never seen any analysis of why a Mustang dyno is a 'real' dyno and others aren't. If you are referencing an article specifically, feel free to share it.
I will say that accelerating a mass to some rpm in a certain amount of time is a pretty fool proof way of determining power, as long as the inertial load provides enough resistance to allow the turbo to spool.
Old 03-28-2015, 04:05 PM
  #25
Its proven a mustang set up properly will show 10-15% less then a dynojet. They are a better dyno end of story.
Old 03-28-2015, 04:13 PM
  #26
smokeshow's Avatar
Still waiting on a reference for that claim... I've heard that through the grape vine as well, but nothing proving it. And I've seen lies come off a Mustang dyno I don't know how many times. What I've bared witness to nobody would be able to tell between truth and anecdotal, so I won't lean on this...but I've seen a modded cobra put down 680hp on a Mustang, followed by my own regular cab truck putting down 50hp less, and then watch it get smaller in my rear view mirror...
Just need some evidence that Dynojets are wrong and I'll believe you.
Old 03-28-2015, 04:42 PM
  #27
Formerly ScreamingL
George C....'s Avatar
if that is the case then when i made 816rwhp on a MD with 11 psi that be over 900 rwhp not likely
setup was stout but thats not likely
MD can be altered way to much
Old 03-28-2015, 08:09 PM
  #28
People see dyno numbers from different tuners out there after installing their products and doesnt realize different dynos provide different results which will make their product not making enough hp and some read too high and this will hopefully iron out that issue. So if you seem a bit confused about the different types of dyno's and what numbers to expect out of them. So let's clear them up.
There are 3 types of chassis dyno's you'll run into in the USA. Dynojet, Dynapack, & Mustang. They all spit out slightly different HP/TQ numbers when you compare one brand to another (i.e. Dynojet vs Dynapack), but they are all 100% consistent if you stay on the same dyno every time. So if you are tracking your mods as you add them, go to the same shop every time.
95% of the shops in the USA are running one of these three dyno's:
1. Dynojet - most popular in the USA. Considered the "standard" here in the states since most shops utilize them. For our theoretical "car", the Dynojet will read 100 rwhp, & 100 ft/lbs of torque.
With this dyno you drive up to the rollers (single roller per wheel ; car sits on top of the roller), they strap the car down, and do a full throttle pass in 3rd or 4th gear. The dyno will calculate the power based on how fast the car will spin the rollers. This is called an inertia based dyno.
For WOT power passes that you can compare to each other on the internet, Dynojet's are perfect. They're everywhere! But most do not have any sort of load simulating capability. Since 2005 more and more Dynojet's sold have their eddy current loading device. So you can ID them, Dynojets are typically red or black.
2. Mustang Dyno's - not as nearly as popular as the Dynojet's, but all performance shops that have Mustang dyno's DO have the capability to simulate load on the car to map ECU's. These are also great dyno's, are very accurate, simulate load very well, and are repeatable every time. They are also inertia based dyno's where you'll drive the car up on the rollers (two rollers per wheel and it sits in between both rollers), strap the car down, and make a 3rd or 4th gear pass.
The Mustang Dynamometer is capable of accurately loading 2WD or 4WD/AWD vehicles for the highest level of repeatability in the industry. We utilize a load-bearing dyno that uses an eddy-current load absorption unit with low inertia rollers for precise and instant torque measurement and power production feedback while the vehicle is running.
These dyno's will always read ~12% LOWER than a Dynojet, which is our standard here in the states (unless the shop has messed with the gearing settings in the computer). Because of this, lots of the internet folk don't like to use them. They come on the internet, share their results and everyone says "why didn't you make more power with mod XX". So our theoretical car will show 88rwhp on the Mustang dyno.
These dyno's will always be blue.
3. Dynapack - These are the red headed step children here in the states. Not as common as the Dynojet or Mustang, but these are the standard in Japan. These are fundamentally COMPLETELY different that the inertia type dyno's.
The Dynapack™ eliminates tire to roller interface variable by using a hub adapter that provides a direct coupling to our Power Absorption Units. There can be no tire slip, no rolling resistance, and no chance of the vehicle coming off of the dyno at high speeds. Notice that we call this a variable. Sometimes it may be a problem area, other times it may not. Tire temperature, pressure, traction, etc, are all variables that can change - not only from run to run, but during the run as well.
With the Dynapack (my favorite), you remove the rear wheels, attach the hubs of the car to the "pods", and make your pass.
The load is simulated on the car via a hydraulic pump. Because these are effectively inertia-less, they will read HIGHER than the standard Dynojet numbers by 8-10%. That number will vary depending on how "fast" your dyno run lasts (sweep time), but as a rule of thumb, they'll read ~8-10% higher. So with this dyno our car will now read ~109rwhp on average.
The pods are always red/black, but these are easiest to ID. If they are taking off your wheels, it's a Dynapack!
And understand one thing when it comes to dyno graphs and product claims! Every dyno graph can be cheated by dishonest individuals/companies. All of them. So always take every dyno claim with a grain of salt. If they are cheating their tests, the truth eventually comes out (usually). Be a smart consumer!
Old 03-28-2015, 08:15 PM
  #29
Yes cause that's the over inflated numbers you would get with the dynojet!
Old 03-28-2015, 08:40 PM
  #30
Formerly ScreamingL
nice copy and paste
Quick Reply: Made 943HP... But what's best way to load a dynojet?
