LQ4 LS3 Heads 427ci Stroker
#41
I had a feeling that Hi Ram wasn't doing you any favors based off of what I felt my Pro Flow was doing to my truck. I've been watching to see how it turned out for you. Between reading this and seeing what stock48 does with his factory intake, I think I'm going to try going back to stock also. I'm already having my fuel system changed to flex and will be getting another tune. So now is as good of a time as any.
#42
If you stay stock L92 intake, careful of cylinder 7 going lean. I have heard of a few builds going south because #7 took a dump.
From what I read, Peak Performance doesn't split the intake for their port work so I might end up buying one of their manifolds.
IMO the bank for the buck was huge. I can't wait to get it tuned
#44
Oh gotcha - I am pretty sure they suffer from the same #7 issue too especially with boost. If I were you I'd save the coin and get an LSX RT - heard many a good things about them. I would have done that except they don't make a square port version of it. I also know that the cathedral truck intake doesn't flow nearly as well as the L92 square port version.
But you are right turn the wick up on that turbo easily overcomes those flow restrictions haha - you will definitely gain in the bottom end for sure over the Pro Flow. Faster boost response I bet which is where you'd feel it on the street.
#45
I have never heard of the #7 going lean (not that I have ever looked into it). It seems to me that if anything the #7 would get less air than the other cylinders. If that's the case and it's getting less air but the same amount of fuel as all the other cylinders, then wouldn't it be richer rather than the rest?
I'm just writing out my thoughts, maybe I'm completely wrong.
#46
For whatever reason #7 is the piston the goes, usually rings or burnt piston from detonation from being lean. Theory is that the air comes straight in and gets channeled back there. Others say it's coolant passages. After looking at the manifold it does look like air can get channeled into #7 almost like a scoop.
Here's a thread about it - I'm sure there is more out there on the topic.
https://www.performancetrucks.net/fo...an-7-a-447199/
#48
I put the coolant vents on the back of my engine for this very reason as well. I haven't yet, but I plan on checking plugs soon and I'll post the results of that too.
#49
Here's the thread I found. It's also the most up to date thread I found.
Lean #7 cylinder - related to Intake Manifold? - LS1TECH
