Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
lq4 + 212/218 + 243s
Old 02-02-2015, 06:35 PM
giiventofly's Avatar
Default lq4 + 212/218 + 243s
My heavy slow truck got tuned today on a friend's mustang dyno.
05 2500hd, 212/218 cam, stock 243 heads, 8.1 injectors, e fans, stock everything else (including manifolds).
It didn't do anything impressive, but I didn't really expect it to. Eager to get it to the track and see the whole story.
And another unrelated picture just because I'm embarrassed of those stock wheels/tires.
Old 02-02-2015, 07:04 PM
SWINGRRRR's Avatar
Good to know!
Sounds very similar to my build except Ill be using LTs.
Thanks man.
Old 02-02-2015, 07:08 PM
Not to shabby! Surely you picked up 40-50hp over stock. I would really love to do this to my 2500 yukon xl.
Old 02-02-2015, 07:51 PM
TXsilverado's Avatar
I'm curious to know how it tows in comparison to stock. I'm thinking about giving my 2500HD the same treatment. stock EVERYTHING except for an intake, 212/218 110 lsa cam, milled 317 heads and a muffler.
Old 02-02-2015, 08:49 PM
Thanks guys. I'll have to let you know on the towing part of it, right now it's still on the small tires and the trailer is covered in snow!
Honestly though if it doesn't make a noticeable difference I'm probably going to need to re-gear. I've been hoping the extra power would act as a nice band-aid for the problem 4.10s and 35s cause.
Old 02-02-2015, 10:17 PM
9 Second Truck Club
stock48's Avatar
What is lsa on that cam? A 4.56~4.88 gear and long tubes would definitely help. I have found the tighter 106~110 lsa's pull the best on the heavy trucks if a guy can handle the chop at idle. Still on a truck that heavy you are going to be hard pressed to feel a huge difference with 40~50 added HP at pk. You need a good tq boost in the 2800~4500 range to really notice it.
Old 02-03-2015, 04:06 PM
I'd probably go 4.88 if I ever do it. It's on a 114 lsa, realistically I probably should've had a custom spec'd cam but I figured for the titanic and stock manifolds etc that the off the shelf comp would be sufficient.
Old 02-03-2015, 07:28 PM
9 Second Truck Club
stock48's Avatar
If it's on 114 you are definitely giving up some mid range tq but with all that weight an extra 20-30 lbs might not be felt that much anyway. 114 will also idle smoother if that's what you are looking for.
Old 02-03-2015, 08:04 PM
10 Second Club
Dyno'd in 2nd gear?
Old 02-04-2015, 10:14 PM
Oh well, it's in there now! Good info for the next guy though, wish I had known.
Originally Posted by 86 IROC
Dyno'd in 2nd gear?
I'm not sure, I wasn't able to be there for it unfortunately.
Quick Reply: lq4 + 212/218 + 243s
