Another 900hp LQ4
#32
Yeah, hasn't had any issues.
I went to the track about a month ago. Went 11.5@121 on 12psi. I don't have enough experience at the track, nor was the truck really set up for it. No suspension straps, street tires, etc.. I'm not a big racer so I haven't made it out again. I just build these things to have fun and drive them
#33
Formerly ScreamingL
very interested to see what youre truck would do on its said psi level at the track
#35
Seeing as my hood is closed for a track pass and up for the dyno run, fairly legitimate. The air intakes draw in a lot of hot air behind the radiator with the hood closed, so the power is expected to drop. I have parts to build an intake to pull cool air from elsewhere, but I've been busy with another truck lately.
#36
Formerly ScreamingL
#38
(posted this on LS1tech, but wanted to give credit where credit is due here on PT, as well)
I know its been done before, probably more times than I know of Just thought I'd post up and give a shout out to a couple people. Gilbert @ Ace Racing Transmissions for a stout 4L80e to take the abuse, Dave @ Yank for making the best converters on the market, and Jarrett/stock48 for his turbo cam. Quick specs on the setup:
2004 Silverado Z71
2006 150k mile LQ4, untouched short block
Stock 317 heads, surfaced
PRC 675 springs
LS9 gaskets
ARP studs
Isky 'triple 12' cam, 212/212 112LSA
Pro Yank 3400 multi disc converter
Eboost street 40 boost controller
ETS intercooler
Twin GT3582r turbos on a flipped manifold kit
Pulls were made on a Dynocom dyno at around 11am in Phoenix, AZ. Ambient temp was 97 degrees. Unlocked converter. Fuel is a mix of 60% E85 and 40% 91 octane. Drove it in on my street tune and left it on spring pressure with the boost controller off. Made some 6psi pulls and I believe it put down 550hp/540tq. Turned it up to 17psi and started seeing 900!
Twin turbo silverado - 935hp/863tq - YouTube
Highest numbers were 950/855. Also made another pull at 946hp, and a couple in the 910-920hp range. The dyno operator only gives the middle pull, so I've got the graph for the 935/863 pull. Numbers are SAE uncorrected. Overall I'm very happy with the power it made as I was not expecting that much at all! The best part was driving 3 hours to the dyno, making a bunch of pulls and driving back in the Arizona heat with AC on and not having a single problem. I had it on 20psi the night before but decided against trying to push the boost any higher in the heat. With a couple more pounds and some cooler weather this might be a 1000hp combo Thanks again to Gilbert, Dave, and Jarrett!
2004 Silverado Z71
PRC 675 springs
LS9 gaskets
ARP studs
ETS intercooler
Mike S
