Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
Another 900hp LQ4
Old 06-03-2013, 02:46 PM
Mod with training wheels
smokeshow's Avatar
Default Another 900hp LQ4
(posted this on LS1tech, but wanted to give credit where credit is due here on PT, as well)
I know its been done before, probably more times than I know of Just thought I'd post up and give a shout out to a couple people. Gilbert @ Ace Racing Transmissions for a stout 4L80e to take the abuse, Dave @ Yank for making the best converters on the market, and Jarrett/stock48 for his turbo cam. Quick specs on the setup:
2004 Silverado Z71
2006 150k mile LQ4, untouched short block
Stock 317 heads, surfaced
PRC 675 springs
LS9 gaskets
ARP studs
Isky 'triple 12' cam, 212/212 112LSA
Pro Yank 3400 multi disc converter
Eboost street 40 boost controller
ETS intercooler
Twin GT3582r turbos on a flipped manifold kit
Pulls were made on a Dynocom dyno at around 11am in Phoenix, AZ. Ambient temp was 97 degrees. Unlocked converter. Fuel is a mix of 60% E85 and 40% 91 octane. Drove it in on my street tune and left it on spring pressure with the boost controller off. Made some 6psi pulls and I believe it put down 550hp/540tq. Turned it up to 17psi and started seeing 900!
http://youtu.be/tPHJaHZ0_Fk
Highest numbers were 950/855. Also made another pull at 946hp, and a couple in the 910-920hp range. The dyno operator only gives the middle pull, so I've got the graph for the 935/863 pull. Numbers are SAE uncorrected. Overall I'm very happy with the power it made as I was not expecting that much at all! The best part was driving 3 hours to the dyno, making a bunch of pulls and driving back in the Arizona heat with AC on and not having a single problem. I had it on 20psi the night before but decided against trying to push the boost any higher in the heat. With a couple more pounds and some cooler weather this might be a 1000hp combo Thanks again to Gilbert, Dave, and Jarrett!
Old 06-03-2013, 02:54 PM
nonnieselman's Avatar
7500rpms?? really?
Thats crazy haha.. congrats!
Old 06-03-2013, 02:55 PM
chevrolet all the way's Avatar
good work man! impressive numbers for sure!
Old 06-03-2013, 03:10 PM
Byrdman11's Avatar
Wow!!
Old 06-03-2013, 03:22 PM
11 sec. Truck Mod
TIM Z's Avatar
Sick man !!! Congrats !!!!!
That's killer, glad to see you get a big payday for your work .
150k LQ4.
Old 06-03-2013, 03:24 PM
oakley6575's Avatar
Damn you wrapped it up. I guess that intake likes it though
Old 06-03-2013, 03:36 PM
Choda's Avatar
Holy ****. Good for u man
Old 06-06-2013, 12:25 PM
slowec's Avatar
Would ya share some fuel system specs?
Awesome job !
Old 06-06-2013, 12:59 PM
smokeshow's Avatar
Fuel system is dual walbro 450s, -8 feed, -6 return, aeromotive FPR and FIC1000 injectors.
Old 06-06-2013, 02:04 PM
Baltimore Whore
Mangled03gmc's Avatar
Bad asssss. I am just about to scratch the idea of building a frgd bottom end, just push the hell out of this damn thing.. LOL
Quick Reply: Another 900hp LQ4
