Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
7.5 and 17.5 PSI pulls
Old 09-28-2015, 08:06 AM
slowec's Avatar
Default 7.5 and 17.5 PSI pulls
Old 09-28-2015, 10:35 AM
Vortec350ss's Avatar
Damn!!! It's amazing that it actually pulls longer on more boost... weird. What is causing it to drop off on the lower setting?
Old 09-28-2015, 11:02 AM
Slowest turbo build ever!
black00chev's Avatar
If I had to guess, at only 7.5psi that turbo isn't even close to running near its max efficiency. Looks like a decently healthy cam too. Looks to me like there is still a few more pounds left in it before it starts dropping off again.
Old 09-28-2015, 11:48 AM
GMCtrk's Avatar
Those Precision turbos always seem to make great power.
Old 09-28-2015, 12:03 PM
slowec's Avatar
The 30 gph meth I was shooting was killing the low setting. Hard to tune on the street beacause it blows the tires off so quick. log shows single digit afr on that low pull. STOCK intake TB fuel rails regulator and lines FTW
Old 09-28-2015, 12:05 PM
GMCtrk's Avatar
stock lines will make well more since you are on gas. I'm pushing similar on straight e85. stock lines and filter.
I'd be curious what it would run in the 1/4 on the 17 psi setting
Old 09-28-2015, 12:14 PM
slowec's Avatar
Low to mid 10's would be my guess.
Old 09-28-2015, 12:17 PM
GMCtrk's Avatar
Raceweight?
Old 09-28-2015, 12:34 PM
Mod with training wheels
smokeshow's Avatar
Looks like it runs real well. Probably stand to pick up some substantial power by picking the timing up if the fueling is right, especially after peak torque. This is my setup a couple years ago, very similar to yours. Only difference is I had the triple 12 and was running e43, no meth, 17psi. IIRC it made 540hp on 5-6psi. Cool to see how the cams compare.
Old 09-28-2015, 02:10 PM
slowec's Avatar
Quick Reply: 7.5 and 17.5 PSI pulls
