Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
5.3, 4x4, TR220, LTs, 3.73s, 33s, and 2nd gear dyno numbers and video
Old 02-01-2014, 10:34 AM
WhiteX's Avatar
Default 5.3, 4x4, TR220, LTs, 3.73s, 33s, and 2nd gear dyno numbers and video
Did a few runs on a Mustang dyno and got my truck retuned.
The runs were in 2nd gear (converter unlocked obviously) with 20x10s and 33" tires.
Mods are TR220 cam and supporting mods, milled 706s (.025), Pacesetter 1 3/4s, K&N intake, and single 3" header back exhaust with Hooker flow through.
Previous tune was based on all the same mods but with stock exhaust and manifolds.
The truck baselined 241/242. After 6 pulls and a bunch of tuning the truck made 271/274 with max hp at 6300 and hitting the limiter at 6500 (only down 2 or 3 hp at 6500).
Numbers weren't high, but the dyno operator told me he recently tuned a bolt on LS1 GTO that put down very similar numbers. So I'm ok with it. I'm mostly happy to have an extra 30hp and 34 ftlbs.
I should note that we ran back to back with the efans on and off and the fans pulled 10hp on the top end! Pretty surprising.
I believe the MAF was flowing somewhere around 445 (or maybe it was 405) g/s at the top. I know that can be equated to HP in some way.
HERES THE VIDEO:
2003 Chevy Silverado dyno run - YouTube
Old 02-01-2014, 12:13 PM
Slowest turbo build ever!
black00chev's Avatar
lbs/min of airflow is a good way to figure out about how much HP your engine is making.
Ex: Last data log I did my truck pulled 39.43lbs/min. Each pound of air is roughly 10hp. So move the decimal right one spot, then multiply by .2 (20% for drivetrain loss), gives you 315. So I can assume Im making just about 315RWHP.
Old 02-01-2014, 03:09 PM
WhiteX's Avatar
Hey thanks. I just texted my tuner and he said it was doing 44.5 lbs/min.
NOT BAD THEN!
Old 02-02-2014, 07:25 PM
Yea you should actually be right around 350 then. Just remember that's all calculated though. Track ETs/MPH tell the REAL tale.
Old 02-28-2014, 02:42 PM
Stocksilver's Avatar
Thank you for the im close to the same set up and waiting to do cam install when i get some more $
Old 03-02-2014, 06:15 PM
AUTOT3K's Avatar
good numbers man!
what dyno were you on?
5.3Okasai
03-09-2022 01:07 PM
thunder550
10-08-2015 04:53 PM
Greatdivider
09-09-2015 09:52 AM
lxcoupe
07-14-2015 10:14 PM
ferrellrooster
07-13-2015 09:53 AM
Quick Reply: 5.3, 4x4, TR220, LTs, 3.73s, 33s, and 2nd gear dyno numbers and video
