Dynamometer Results & Comparisons Dyno Graphs | Power Comparisons | Dyno Truck List
2011 Silverado TVS 1900 Dyno question
Old 12-15-2016, 11:12 AM
69CapriceHDTP's Avatar
Default 2011 Silverado TVS 1900 Dyno question
2011 Silverado 2500 6.0 TVS1900 with ported 2300 lower tub and 3.2" pulley. So I got my truck dyno'd and obviously the 3rd gear pull is the 1:1 ratio, he would not do it in 3rd because he says these trucks will lose the driveshaft at the top end of 3rd because they are unbalanced. The truck did 362rwhp in 2nd gear, any way to calculate what that would be in a 3rd gear pull? The number just seems low to me. It was done at 8lbs boost, where under load on the highway I can pull 12lbs.
Old 12-15-2016, 01:13 PM
Vortec350ss's Avatar
Your truck is actually 1:1 in 4th gear with the 6 speed trans. A second gear dyno is going to read very low as you pointed out. He is right that its common to toss a driveshaft at the top of a 1:1 gear in a big truck.
Interesting that boost was low though. I can see it maybe being a tad low on such a short pull, but 4 LBS is a ton.
Old 12-15-2016, 10:40 PM
ZO6Ted's Avatar
Think its 1.15. They did mine in 4th. NM its a 2500...
Old 12-15-2016, 11:16 PM
Nope you're still right.
Old 12-19-2016, 08:04 AM
So is there any way to calculate the difference?
Old 01-27-2018, 09:05 PM
Registered User
SUPERCHRGEDGMC's Avatar
You should be over 500. I have a 5.3 in mine an i have the 1900 also an i did a dyno an mild tune an im at 468rwhp.
Old 01-28-2018, 05:36 AM
madmann26's Avatar
It's not that the driveshaft is unbalanced it's very very thin material.
You need to invest in a built driveshaft before bad **** happens.
Old 01-28-2018, 06:23 AM
smokinlmm's Avatar
X2... I hit 485 with my 5.3 and 1900. Who tuned it?
Old 01-28-2018, 07:57 AM
Mod with training wheels
smokeshow's Avatar
Stock cam?
Old 01-28-2018, 04:23 PM
I have a gauge for that
Atomic's Avatar
Tires make a huge difference as well. That number isn't that out of line for 8psi and 35"+ tires.
