Drivetrain & Suspension Chassis | Transmission| Driveshaft | Gears/Rear End/Differential | Traction Aids
Stock gears in 2000 Silverado
Old 02-05-2012, 02:11 PM
OHH RLY?'s Avatar
Default Stock gears in 2000 Silverado
I just picked up a 2000 Silverado and was curious of the stock gearing on these. It's a 5.3L FWIW. Thanks!
Old 02-09-2012, 03:38 PM
06Sierra2's Avatar
is it 4x4? if so you probably have 3.73s otherwise if 2wd its either 3.23 or 3.42. you can look up the vin numbers and find out or check the glovebox codes, try searching for some threads about it
Old 05-01-2013, 09:27 PM
2plus2's Avatar
Gu4 -- axle rear, 3.08 ratio
gu5 -- axle rear, 3.23 ratio
gu6 -- axle rear, 3.42 ratio
gt4 -- axle rear, 3.73 ratio
gt5 -- axle rear, 4.10 ratio
g80 -- axle rear, limited slip differential (positraction)
g86 -- axle rear, electronic locking differential
Ketis
07-23-2015 12:37 PM
lxcoupe
07-21-2015 02:12 AM
Suburban2500
07-19-2015 04:50 PM
Mossyoakglock
07-17-2015 08:30 AM
ferrellrooster
07-13-2015 09:53 AM
Quick Reply: Stock gears in 2000 Silverado
