Drivetrain & Suspension Transmission | Gearing | Traction
converter question
Old 09-13-2012, 10:33 AM
i20rider's Avatar
Default converter question
After along time. To factory converters go bad. .im about to rebuiod ky trans. But not sure if i need to get a new stall aswell. I do use the truck for towing so i may wona stick with the factory stall.
Old 09-15-2012, 10:49 PM
i20rider's Avatar
Nothing?
Old 09-16-2012, 02:28 AM
Budakane's Avatar
Factory stalls will last as long as the trans, but if ur beefing it up, i would also go with a beefier stall. Im doing the same thing
Old 10-10-2012, 12:05 AM
HemiLonestar's Avatar
Most times an aftermarket converter (even if the same stall speed) will be a higher quality/work better than a factory one. I still tow and lug **** around so I didn't go any higher than 2800 rpm stall on my Circle D (it was what they recommended). Call or email the various TC manufacturers and get their recommendations (based on mods and what you use it for).
Old 10-10-2012, 06:34 PM
Ph.D. in HUBRIS
custm2500's Avatar
You should certainly replace the converter. A few reasons why
It holds tons of fluid. Ususally about half the capacity. You will never get all the crap out of it so you a making a fresh trans VERY dirty.
They do have a life and if the trans needs freshend up, the converter probably does also.
To stick with a stock stall has one good reason, saving money. To not install a slightly higher stall is a great way to waken up the truck a bit. Something in the 2800 range like said before will feel stock but if you get the itch to jump on it then you will have a big grin. A mild stall from FTI(and others) isn't much if any more then you will pay for a stock converter.
GXPJAY
02-13-2022 08:15 AM
Jblake
08-17-2015 12:59 PM
USMCvet0311
08-01-2015 07:45 AM
WICK3DxGATA
07-21-2015 06:59 PM
grantpo
07-15-2015 12:21 PM
Quick Reply: converter question
