SHATTERING the 4.8 record once again!
8 Second Truck Club
Wow is all I can say. Good work for sure.
I know it is stupid cliche, but with the kind of mph at the 1/8 and 1/4 that this thing is running , it may suggest that there even more et to be had. 1.55 60's on a truck this quick isn't bad, but it isn't great either. How much boost/timing are you leaving on, and how does the boost and timing ramps look? 4400 lbs is a lot to get rolling, but I'm wondering if you can get some low 1.40's out of it in the first 60'?????...
As far as timing it's starts at 16* and stays that way across the pass but it did drop to 11* because of iats getting too hot. Boost ramps in quick. I have the 2 step set at 3300 rpms on the transbrake which is 11psi and by 6300rpms it's at 26psi. I can post a screenshot of the data log if you want to see.
