Need advice on some 15in dr
True, but been reading up on these suppose to be better than last Gen. even have better water channeling! If you got caught in the rain with old style it was a **** show!!!!
8 Second Truck Club
My biggest reason above was the fact that the really good drag radials on the market these days have a normal driving tire life of nothing. So you will be constantly buying tires.
I'd come up with a different plan to have legit street tires on it for the street and a set of dedicated drag tires. There are nothing but pros to doing this. It saves you money and may save your truck/life. Not to mention, if you dedicate a tire to the track, that tire will perform better at the track as it has not been beaten up on the street.
8 Second Truck Club
Your original posts says "daily and track use". Unless you live at the track and make passes everyday........your above statement of "honestly it will see more track than street" doesn't work.
So I digress,
Your statements in post 1 and post 8 contradict themselves. In order for you to decide what tire is gonna be best for you, you need to be honest about what the truck/car is being used for.
I'm not trying to be a dick or anything.....I'm just saying that running the M/T 275 Pro drag radial (arguably the best drag radial on the market) on your daily driver is probably not a good idea.
So I digress,
If you want a dot radial for the track that will be occasionally driven on the street:
MT ET Street SS - Best if more street use and will see wet weather.
MT ET Street R - Better for track, no wet weather
MT ET Street Pro - Best for track use, no wet weather
Hoosier DR - Best for track use, no wet weather
Nitto NT05R - Good for street use, limited wet weather
Size will play a big role in choosing from tires above as there may not be a common size between all of them.
I totally agree with the above statement and is what I do for my fun truck. I actually have three sets of tires for different uses. I run a 265 radial front and 305 dr out back most of the time but do my best to avoid any wet weather driving. I actually wrecked the truck a few years back on a NT05R in the rain when the converter locked up at 35mph and broke the tires loose. I was able to avoid opposing traffic but the car behind me hit me in the front after doing a 180. I am currently running the older MT ET Street2 and got caught in a rainstorm earlier this year. They did better than the Nittos but I was nervous as a cat in a room full of rocking chairs. Constantly driving a drag radial on the street will also harden the compound thru heat cycles and uv exposure. Not to mention the very limited mileage. For the track I still run a DOT tire for True Street races but that is the only street use they see. I chose the Hoosier DR over the MT ETSS due to the lighter weight and increased contact patch. For autocross and potential rain driving, I have a full set of NT05's.
