GM guys lets see your 4WD drag set ups!
#34
Ok so I went out and installed a bigger wastegate spring that allows me to build more than a 7psi launch...lucky I was 1/4mile from the house because I had to drive home in 4hi. Apparently I will need traction bars to launch on 13psi, because the rear springs wrapped and busted the rear universal joint. Luckily it barely smacked the gas tank and sheared 2 caps off the joint, the ds survived. Time for cal-tracs or Smith Racecraft! LOL!!
#35
11 Second Hall Moniter
The track manager(in my case track owner) was not impressed or happy about it.
With straps & CalTracs, and drag radials, I could still have some tire spin on the launch, but it became manageable.
#36
Before I strapped the front it would buck a little and pull hard left. The straps fixed that problem but my truck was lazy to build boost with the 5lb spring in the gate. With the 9lb spring the boost comes on violently and this morning was the first time I have tried to launch over 8psi. I think I'm gonna go with the Assassin bars and some adjustable rear shocks
MileHighSierra
07-22-2015 11:19 PM
lxcoupe
07-21-2015 02:12 AM
