first track pass since truck was totalled
Went to a 8th mile track today and wanted to see what im starting with since the rebuild. Previous best before accident was 7.65 at 88/12.09 at 110 on 9lbs with a 1.69 60ft. Truck had a turbonetics 62mm turbo at that stage. During the rebuild I swapped it out for a 70mm master power. Truck is still on 9lbs, maf tune, 14 degrees of timing, shifting at 6200. todays first pass off the highway was 7.70 at 88, 1.68 60ft. Truck will be SD tuned in next couple weeks, and hope to pick up some power. Im still stoked for what it did run though, a good starting point. heres a vid of todays runs. First pass was good, second, not so much, the truck in front of me got water on the track, and i spun pretty good, then the trans lost it brain, and i was hitting the rev limiter on the 2-3 shift.
https://www.youtube.com/watch?v=EqAb...ature=youtu.be
Little truck hauls butt. Great run.
BennyB
08-01-2015 08:48 AM
GMCtrk
07-17-2015 06:39 PM
