TIME SLIP DATABASE
First time out with new mods - better than expected
Old 09-18-2014, 06:11 AM
vettelovralexand's Avatar
Default First time out with new mods - better than expected
I had a great night out last night at Lucas Oil Raceway in Indianapolis. Lots of great cars running and great air with it being mid 60s out last night. DA was around 1400, so I pulled in fresh off the interstate after 2 hours and laid down these two passes:
I tried working on my launches later in the night, but I am still having some issues with timing being pulled sometimes when powerbraking and not others, and also trying to work out the best time to shift out of 4wd to maximize time. I think with a good set of tires that I could hook out of the hole I may be able to cut another tenth or two off. But, I couldn't be happier. As a reminder, here was the truck in similar DA at Edgewater before the supercharger and headers:
Not bad picking up 2 seconds and 12+ mph! Unfortunately didn't get a video, unless I can find something on Youtube from one of the guys I raced with a go-pro.
Old 09-18-2014, 08:25 AM
Vortec350ss's Avatar
Good stuff. How much boost are you running?
it won't take much to get those times down a lot further.
Old 09-18-2014, 08:26 AM
GXPJAY's Avatar
Nice gains, how much boost is that thing producing?
Old 09-18-2014, 09:09 AM
07bluelbz's Avatar
Will the 1/2 tons come out of 4wd under wide open throttle??? I know my Duramax wouldn't.
Old 09-18-2014, 09:15 AM
The truck makes 7-8 lbs the way it is now. I am putting together funds and parts to do a cam swap and at the same time will probably swap to an overdrive crank pulley since I can't swap the upper.
And, yes it would come out of 4wd during the run. I think that it actually caused me to lose time on one of my later runs because I spun during the 2-3 shift.
Old 09-18-2014, 09:41 AM
GXPJAY's Avatar
I've never tried to come out of 4WD during a pass but I wouldn't think it would save too much I mean the truck's already moving, would be good to find out though.
Old 09-18-2014, 06:58 PM
To be honest my 1st run with it in 4wd the whole pass had more vibration I could feel, but didn't run any substantial amount slower than the other run so it may not be worth it. May have to go try it out again sometime.
Old 09-18-2014, 06:59 PM
Slowest turbo build ever!
black00chev's Avatar
Ive ran back to back before 4wd and 2wd, you can feel a huge difference in drag in the drivetrain between the two. But for me, it wasn't worth trying 2wd beause I spun out of the hole and spun on the 1-2 shift. My times are WAY more consistent in 4wd.
Oobray
06-13-2022 03:38 AM
fastjweb
08-15-2015 10:47 AM
abey15
07-13-2015 02:20 PM
Quick Reply: First time out with new mods - better than expected
