Any guesses on ET?
Any guesses on ET?
truck went 11.02 at 121.2 with a 1.56 60ft, 70mm master power, 15 psi, 11 degrees to the 8th, down to 9.5 degrees due to iats on staight 93. Just installed a turbonetics 78/75 BB .96ar and 50/50 meth. Will probably be running 14 degrees of timing and 15 psi. Not sure what to expect out of it. Should be a solid 4-5 degrees more timing across the board.
yeah, looks like the TR1245 is the way to go. How much of a issue is it getting rid of part of the A frame. Currently the trans cooler is behind it, would like to notch cut that A frame that way it will give me added room for the 4". right now 3" in front of A frame, and grille just touches it.
