03 ram 1500 no power without the key ON
Old 01-20-2012, 08:07 AM
stranger ranger's Avatar
Default 03 ram 1500 no power without the key ON
Got a buddy of mine, older fella, who has zero mechanical knowledge. All he knows is turn the key and go. Well recently his radio stopped working all together, truck on or off, and when you remove the key from the ignition nothing on the truck works at all. Its as if when you remove the key you're cutting all power to everything on the truck. No lights, no horn, no door locks, nothing.... But, when you turn the key to the ON position, or back to accessory, all power is back. Checked the obvious fuses first then after seeing those weren't bad, we pulled just about every fuse out of the panel and didn't find any blown. Found some stuff on google that says fuse number 51 is blown but upon inspection, it looked fine. Does anyone have ANY idea whats going on here???
Again, Key on or at Accessory, everything work but radio. Truck running, everything works but radio and lastly when the key is off or out of the ignition, nothing work at all.
Old 01-20-2012, 04:13 PM
FrostKing's Avatar
There is a timer that cuts power to protect from draining the battery. As far as I know it only monitors if the interior/exterior lights are left on after the key is removed. I don't know if this cuts power to the locks and horn as well, but it may be worth looking into.
Old 02-01-2012, 11:48 AM
turned out it was a corroded, frayed wire underneath of the fuse block under the hood. fixed and everything is good now.
Old 08-29-2013, 03:36 PM
Registered User
spin42's Avatar
Stranger Ranger.
I'm experiencing the exact same thing with my truck.
Do you remember what wire was corroded under the fuse box?
Thanks
Old 08-30-2013, 11:22 AM
FrostKing's Avatar
Originally Posted by spin42
Stranger Ranger.
Thanks
Probably all of them. The '03s never came with a cover under the fuse box, like the newer trucks, and they are notorious for corrosion there.
thunder550
10-08-2015 04:53 PM
signguy62
09-20-2015 02:05 PM
Austino
07-30-2015 03:28 PM
signguy62
07-25-2015 03:12 PM
FlowmasterMufflers
07-09-2015 11:35 AM
Quick Reply: 03 ram 1500 no power without the key ON
