Dodge Engine & Exhaust Performance All EFI, Hemi, Magnum, 4.7, 5.9
CFM on stock Hemi exhaust
Old 01-10-2011, 01:14 PM
Budakane's Avatar
Default CFM on stock Hemi exhaust
Does any1 know what the CFM is on a 06-08 hemi 1500 stock exhaust is?
Old 01-10-2011, 10:35 PM
FrostKing's Avatar
Exactly the same as the engine it's attached to. There is no answer so you need to re-word this.
Old 01-11-2011, 07:58 AM
Budakane's Avatar
basically I want to change out my muffler, iwant more poewr so I wanted to know the cfm flow rate on the stock setup, the muffs I have now are at like 470, and I am trying to figure is that a signifigant diff in stock enuff to keep or should I upgrade
Old 09-18-2014, 01:13 PM
Budakane's Avatar
Bump!! Looking back on my original question it doesn't make much sense. Doing research I found that the CFM/exhaust flow rate for 3in straight pipe is 598. Building a performance rig you want as much flow as possible, so the closer to 598 the better. My muffler has a cfm of 470, but noticed noone has the flow rate for stock exhaust systems. I am leaning towards s muffler swap...I feel its my weakest link. I have longtubes, 3in ORY, and 3in custom piping dumping at the axle. Does any have an answer to my question or a alternative to my 3in Cherry Bomb Pro muffler? Thanks
Old 09-18-2014, 05:46 PM
Former Vendor
FlowmasterMufflers's Avatar
CFM is measured using a flow bench. A flow bench produces a steady, low temperature stream of air and lacks the acoustical and thermal dynamics that are produced by an internal combustion engine. For that reason a CFM rating isn't much of an indicator of muffler performance.
ARC
57
02-21-2022 10:54 AM
OLD BULL
08-01-2015 05:00 PM
Chiphead
08-01-2015 04:43 PM
GMCtrk
07-17-2015 06:39 PM
Rwilliams85
07-14-2015 04:36 PM
Quick Reply: CFM on stock Hemi exhaust
