Removing something from the Turbo?
Old 08-13-2009, 11:04 AM
SS T56's Avatar
Default Removing something from the Turbo?
I've heard about removing some sort of resonator/ ring from your factory turbo on 5.9's. Whats up with that and what are the benefits? Thanks!
-SS
Old 08-13-2009, 11:30 AM
charcold-bowtie's Avatar
I think its called a turbo silencer. My friend pulled his off his 02? cummins, not sure of any details of it.
Old 08-13-2009, 11:43 AM
SS T56's Avatar
That's what I'm looking for, someone with some tech. info on it.
-SS
Old 08-13-2009, 11:52 AM
google
Google is your friend
Old 08-14-2009, 10:50 AM
High Voltage's Avatar
It's all about sound. If you have an aftermarket intake, the turbo whine can get quite loud. Just a thought versus those that run no silencer with factory air boxes...
Old 08-17-2009, 10:22 AM
SS T56's Avatar
Annoying too loud? If I plan on just doing the silencer removal, and a 6637 will it still be real loud?
-SS
Old 08-25-2009, 05:37 PM
tank454's Avatar
-SS
It can be. We took one off my buddy's 24v Cummins and anything over 2200rpm's, its almost hard to hear yourself talk. He's running an AFE stage ll intake and a 5" MBRP exhaust. Maybe it won't be so annoyingly loud if you are running a stock setup. I don't think it adds any power, just in case you were looking for that.
Old 08-30-2009, 01:04 PM
cummin not strokin's Avatar
if your talking about the silencer ring i took mine out of my 05 and you get used to it really fast its not that bad at all and i have a intake and 5" turbo back no performance gains but you can tell you have a turbo thats for sure
Old 12-05-2009, 11:26 PM
Tall_n_turboed's Avatar
Default silencer ring removal
to remove the ring its pretty ez, all you have to do is take the intake tubing from the air box to the turbo off, than if you look in the turbo you will see a snap ring and one side is cut at an angle to where you can get a flat head screw driver and pry it out. after you remove that, the silencer ring will just pull out. Also to get more turbo whistle (if you are still using the stock intake) theres a section in the intake tube that looks like a 8 inch long can in the middle of the tube and inside there is a piece of plastic shaped like a cross with a bunch of small holes drilled in it, just pry the end of the area where the seem is apart and pull the cross shaped thing out and use some pvc glue or scilicone to place the end back to the pipe
Old 08-15-2010, 09:32 PM
05rado's Avatar
its just a silencer ring removing it will make your turbo whistle just a little louder but over all not much difference
Quick Reply: Removing something from the Turbo?
