help with bleeding pump
11 Second Club
long story short. I replaced the lift pump. Bled the pump. i have fuel to 4 of the 6 injectors whre it goes in the head. It will crank and hit for just a second and then go back to cranking. Letit sit a few minutes and it will do the same. Any sugestions?
Registered User
I assume this is a VP truck? Need some info first.
Did you replace factory lift pump with another factory pump?
What was the reason for replacing(quit one day, low pressure, hard start, etc)
I have seen trucks do this when there is alot of air in the system, it will bleed out and start but takes a little time.
Which pump is it? If its a VP (1998.5-2002 24 valve) then if the lift pump went bad, then the injection pump is most likely toast. They are fuel lubricated and usually take a poo when the lift pump does. Do a google search for VP pump failure for more details. If it is a P-pump (1994+ 12 valve) Then you need to just bleed the ever-loving crap out of the injection lines. It can take a while to get all the air out.
rednekferlife101
09-14-2015 05:27 PM
