project SARGE, the bagged 67 turbo burb build
#121
Evap purge solenoid plug ordered... and now installed.
More parts for the burb showed up... More exhaust heat wrap, and a new coolant temp sensor since I broke the one on the 5.3 when I was transporting it back home
SARGE has his matching stars and bars now for once he's finally back on the road
New longer and better trans dipstick showed up today
#122
#124
some updates...
New trans dip stick installed. Just need to replace the self tapping sheet metal screws with some bolts and lock nuts
Step one of the conversion back to manual disc brakes completed.
Under hood portion of the power to manual brake conversion done. Just need to paint the one line to match the rest of them. Then bleed the brakes again after mounting the brake pedal rod (brake pedal rod has been installed since pic). brakes still need bled though
Bottom cut out of the "battery box cover" I had bolted down to the floor. Next step is building a box to hold the battery, cut a hole in the floor, drop it down in, weld it up, then bolt this back to the floor
Floor cut out for battery box
Some more sheet metal to build the "battery box" out of, and to make more panels for the floor so it can be closer to being done
Battery box cut out...
And formed. Just need to weld it up, then weld it into the floor
And welded up and grinded down. Not perfect, but good enough. Now just gotta weld it into the floor
And welded in...
And some paint on it
New gas cap/filler I've had that's gonna go on it. Most likely gonna use some round tube and build a base for it, to raise it up off the floor just slightly, and maybe at a 45° angle
Battery cable through panel connectors installed. Now I need to make and run all my battery cables, and relocate some other stuff into the empty spot next to the battery
And the race car battery relocation kit I've had, that I bought to do that with
Old homemade drivers side CB/radio antenna mount removed. And new one modified slightly and temporarily mounted in its new location on the rear bumper (where I wanted in the first place). Just gotta do the other side. And they will be getting painted, most likely black.
Another piece of the puzzle (5" exhaust tubing) to modify to work for what I want/need
That should work for a color change. One down one to go.
Other one modified and temporarily mounted. Now to capt it with some plastidip like I did the other side
And welded in...
#125
And both mounted to the bumper and "painted"
Cut, stretched, welded, and capped one end to use as a mounting surface for the fuel filler cap. Now just gotta grind the welds down and clean it all up, then drill/cut a hole in the center for the fuel hose to run through.
I guess that's one way to figure out, and make the angle I wanted. Lol. Chop saw wasn't big enough, and this piece is to small (length) to cut it. So now I can do it with a grinder and a cut off wheel
Done cutting and grinding the angle just right.
That'll work. Just need to make the hole in the floor bigger, drill some holes to mount the fuel filler, and weld it to the floor
And hole cut out bigger, and moved over to the right a little bit farther
#128
Here's the idea I was going for when I started this new idea. May clock it 90° to the right so I flips open towards the passengers side. Or 180° so it flips down. But we'll see as I finish it
And welded in and mounted... Just need to scotch brite (or sand it) to make it not shiny. Lol
Think I'm gonna add one of my spare .50 CAL ammo cans in this spot...
Got some AC-130 gunship, and A-10 warthog ammo casing thanks to a really good friend
Gonna use this one for the shift lever arm
Working on the 30mm A-10 warthog bullet case shifter handle
Shifter handle for the burb done... Just need to reinstall it.
And reinstalled... I like it.
shupe
08-05-2015 06:45 PM
