project SARGE, the bagged 67 turbo burb build
got all the windows limo tinted and half *** cleaned up the back a bit
time for a full color change, so i wire wheeled the whole quarter panel and started spraying some tan paint
all one color, and got some different wheels, and some new tires for more of a hot rod look
got two more tires like what was on the rear...
a "photochop" of what it may end up looking like
a drawing i did of how i want it to look
picked up some different wheels and tires.... didn't like the all chrome so i did some painting on them
got some smaller tires and dropped it back down, and painted some of the grille black as well. then put some clear turn signals on
cleaned up and painted the engine to make it look a bit better
a few stickers and stuff i did to the back, as well as mocking up some Cadillac tail lights
cutting out some metal so i can weld in some tail light buckets
swapping out the th400 for another th400 thats in better shape
the massive gas tank
done with trans swap
doing some more welding, and test fitting the lights, and checking the wiring
done enough with them for now... now a bit of paint to keep the rust away
DOH!!! lol
welding in the step notch the rest of the way
swapped out the damaged fender with a temporary one, swapped out the grille for another one, and decided to start painting the wheels all black
first car show
got another better fender
messing around a bit
redid the cluster for now
made a firewall block off panel
out for a cruise, also swapped out the other fender
deciding on which way i wanna go with the look and color
dropped the back a bit more.... and this is static dropped
got some new wheel tubs for the back
got the rear wheels painted black finally, repainted the front clip, painted all the rear suspension, frame, and wheel tubs
figured it was time for another color change.... i like it much better than the tan
swapped out the old long tube headers for some stainless shorty headers
swapped out the bench seat for some bucket seats
gonna make some upper bag plates for the front
bagging the rear with a home made setup
second car show ever
mine, and a friend of mine's suburban
full lift in the rear
