project SARGE, the bagged 67 turbo burb build
#91
#92
Transmission painted the same color the 5.3 will end up (cast iron). Just need to replace a few more seals, add a drain plug to the pan, paint the pan, and it will be good to go... at least until I pull it again for a full rebuild, shift kit, and beefing it up to handle the turbo setup that's gonna end up on the engine
Trans pan cleaned, pan rail straightened, homemade drain plug welded in, and painted
Done... other than some clear coat, which will come when the engine is painted and clear coated
#94
Building a mounting bracket for the 5.3 ecm
and done... other than some paint. Might not use that particular rubber isolation mount either
Well... i lied a little bit. lol. i decided to add a few mounting tabs to the ecu mount before painting it. 4 of them for the cover im gonna make out of some abs plastic, and 2 of them to mount the under hood fuse block as well
#95
