project SARGE, the bagged 67 turbo burb build
#81
#82
#83
more updates...
Cleaned up and partially painted. Relocating the front air ride valves off of the firewall, since the passengers side ones are gonna be in the way of the exhaust dump/cutout once its turbo'd
Coating the SloshTubz with some rattle can spray on bed liner as well while I have it apart
Future exhaust cutout/dump location. Might cut/notch a section of the fender bracing, and firewall for some extra clearance, and so I can run it out the fender at a 45° angle
#84
more updates. lol.
got the other fender off, and finished painting the firewall and stuff
got the other SloshTub coated in bed liner as well
And back on. Now I gotta make a make a block off plate for the clutch linkage hole, remount the air ride valve somewhere else, remove the old fuel line, and do a few other things. Then it will be ready to drop the 5.3 in once that's ready
Clutch pedal linkage hole cover, and accelerator pedal rod hole cover made, painted, and installed
#87
#88
Making custom truck parts... got the tools made to make the molds for the final products. These are standard size radio delete plate molds/tools, and a couple of custom ones being made. Not pictured/made yet, is a double DIN one for when I put a dvd/cd/radio in. The long one will be used to hold some extra gauges (once I go turbo), a dual usb charging port/cig lighter, and the ignition switch. The standard size one im not using. These are being made out of fiberglass, and are nice and thick/strong
#89
Tool made for custom gauge/ignition/cig lighter/usb charging port, mounting panel
Final product is made. Just need to do a little fine tuning and a little pin hole filling.
fits where the stock heater controls, ignition, and cig lighter on a stock dash goes too. but mine is a flat surface in this area
Doing some mock up if a few things so I can figure some stuff out. Got the f-body dip stick tube bent to clear the headers... but looks like I'm gonna have to do something about the coil packs because the front ones shoots the spark plug wires into the header tubes. Guess I'll have to make some new brackets or something to move them around to somewhere else so the wires will clear the headers
Ignition switch hole cut, ignition modified, and gonna do the cig lighter/usb one next, as well as epoxying on some mounting studs
In primer. Need to sand it and do a little spot putty work, then it'll be ready for some satin black paint
