project SARGE, the bagged 67 turbo burb build
#71
Making one piece window brackets for a future upgrade on the burb? Don't mind if I do. Lol
Went and got some steel for me and my buddy that is making a set for his truck too. so we will probably be cutting these window corner pieces, for the front of the doors out tomorrow
#72
#74
Front turn signal light housings for the 67 GMC front end before bead blasting...
And after. Much better now. Now they just need painted silver on the inside, and black on the outside
That should make getting the engine and trans out in one piece a hell of a lot easier. Same with when the 5.3 and the th400 trans go back in in one piece... and the GMC grille swap
After paint... looks much better now
GMC hood latch blasted, and painted
Bumper brackets, cross member, and radiator core support brackets (passengers side was loose) removed from frame for for clean up, and repaint when the engine comes out. May make a new and cleaner looking cross member to put back in, so that way I have more clearance and room for other things
#77
New DOM cross member built to go under the radiator core support. Just need to cut down/round out the corners on the end plates
Modified the stock bracket for the "new" trans cooler, and drilled the core support for its new location.
One down one to go... 4" holes for the piping of the intercooler on the future turbo setup.
and done... drilled a few other holes for some things that need mounted up to this core support as well. MIGHT get a couple of small pieces of 4" tube to weld in and finish it off to make it look even better
#78
#79
#80
