project SARGE, the bagged 67 turbo burb build
Old 04-08-2015, 10:47 PM
  #71
project 67 sub's Avatar
Making one piece window brackets for a future upgrade on the burb? Don't mind if I do. Lol
Went and got some steel for me and my buddy that is making a set for his truck too. so we will probably be cutting these window corner pieces, for the front of the doors out tomorrow
Old 04-16-2015, 01:48 AM
  #72
more updates...
Door window corner pieces cut, drilled, and tapped for screws. They fit great too. they are at the powder coaters now
And... this is a (67 GMC) swap that's gonna be happening in the future as well. trading my chevy grille for it. it will end up powder coated satin black as well
Old 04-16-2015, 09:47 PM
  #73
Back from the powder coaters... and they sure do look good.
Old 04-22-2015, 12:16 AM
  #74
Front turn signal light housings for the 67 GMC front end before bead blasting...
And after. Much better now. Now they just need painted silver on the inside, and black on the outside
That should make getting the engine and trans out in one piece a hell of a lot easier. Same with when the 5.3 and the th400 trans go back in in one piece... and the GMC grille swap
After paint... looks much better now
GMC hood latch blasted, and painted
Bumper brackets, cross member, and radiator core support brackets (passengers side was loose) removed from frame for for clean up, and repaint when the engine comes out. May make a new and cleaner looking cross member to put back in, so that way I have more clearance and room for other things
Old 04-22-2015, 08:17 AM
  #75
BigDaddy0381's Avatar
Very nice build.
Old 04-23-2015, 03:56 AM
  #76
thanks. and another update... but no pics this time (yet). ordered/ordering a ton of parts for my "LS" swap, and GMC grille conversion.
Old 04-27-2015, 03:25 AM
  #77
New DOM cross member built to go under the radiator core support. Just need to cut down/round out the corners on the end plates
Modified the stock bracket for the "new" trans cooler, and drilled the core support for its new location.
One down one to go... 4" holes for the piping of the intercooler on the future turbo setup.
and done... drilled a few other holes for some things that need mounted up to this core support as well. MIGHT get a couple of small pieces of 4" tube to weld in and finish it off to make it look even better
Old 04-28-2015, 05:48 AM
  #78
Sneak peak of some of the things I plan on using some bullet casings for.
Trans cooler, and modified bracket cleaned and painted... looks basically new again. Now I just need to find some new line fittings for it
Old 05-04-2015, 02:24 AM
  #79
Gonna start doing clean up, a few mods, and changing/replacing a few things soon for the swap
98-02 f-body oil pan swap, and a -10AN bulkhead for the turbo oil return done
Old 05-07-2015, 10:19 PM
  #80
Heck yes! New rods, and main bearings came yesterday. Replacing them just for piece of mind (since it supposedly came out of a rolled over tahoe).
More truck parts (50bmg).
Quick Reply: project SARGE, the bagged 67 turbo burb build
