Flowmaster's American Thunder Crossmember-back System for '73-'87 Chevy/GMC C10/C20
Old 08-31-2015, 05:11 PM
Former Vendor
FlowmasterMufflers's Avatar
Default Flowmaster's American Thunder Crossmember-back System for '73-'87 Chevy/GMC C10/C20
Flowmaster Part #17742
Special Note:
Not emissions compliant on vehicles originally equipped with a catalyst system. This system is not designed as a direct bolt-on and will require the user to fabricate pipes to connect to manifolds or headers.
Application:
1973 to 1987 Chevrolet and GMC C10 (1/2 ton) and C20 (3/4 ton) Pickup Trucks, 2 Wheel Drive Only.
Flowmaster's American Thunder Crossmember-back System for '73-'87 Chevy/GMC C10/C20-9esajyo.jpg
Features:
Flowmaster's American Thunder Crossmember-back exhaust system for the 73-87 GM C10/C20, and 3/4 ton, 2WD pickup truck is perfect for the person looking for moderate to aggressive sound levels with all of the performance benefits that you would expect from Flowmaster. This Crossmember-back DOR/DOS (Dual Out Rear, Dual Out Side) system features dual Super 44 Series mufflers, 2.50 mandrel bent aluminized tubing and accommodates both dual and single exhaust crossmembers. This system is routed in a fashion that accommodates both long and short wheelbases with automatic or manual transmissions, and provides adequate clearance for substantially lowered vehicles. The exhaust system is manufactured in the USA and is covered by Flowmaster's 3 Year Limited Warranty. Note: This system is not emissions compliant on vehicles that were originally equipped with catalytic converters. This system is not designed as a direct bolt-on and will require the user to fabricate pipes to connect to manifolds or headers.
✓ Famous Flowmaster Sound
✓ Multiple Exit Options
✓ Patented Delta Flow Technology
✓ Made in the USA
Pimpinpete
43
12-22-2017 08:13 AM
turbo6c3
10-05-2015 06:11 PM
Slammed silverado
09-28-2015 06:14 PM
FlowmasterMufflers
09-11-2015 03:32 PM
Quick Reply: Flowmaster's American Thunder Crossmember-back System for '73-'87 Chevy/GMC C10/C20
