92 c1500 problem
92 c1500 problem
Ok ive got a stupid question. What in the world is this in the pic. Im still trying to diagnose my problem. If you floor the truck from a dead stop it will surge in and out at WOT. Almost like the fuel is cut of and cut back on but im almost positive thats not it. Ive put new fuel pump, fuel filter, and distributor cap and rotor. Where should i look next. it does not feel like a common misfire or anything.[IMG][/IMG]
could this be a problem as well? Not sure but these plugs look pretty tired. lol. Just don't want to spend a arm and leg to fix easy problem im thinking.[IMG][/IMG]
replace those plugs and wires.then go from there.
BTW the 1 module with the line going to the TB is the egr solenoid,i forgot the other part with the large harness.Who the f*** mounted the map sensor like that?check the vacuum from the map sensor to the back of the TB also.Why is everything rigged you have a spring on the thorttle bracket for what?
then i just feel bad for you.I would never have bought a truck rigged up like that.I dont even want to look at the lifter valley or in the heads probably 15 pounds of sludge.
While you're at it go for a new oil pressure switch, they tell the fuel pump to run while oil pressure is being made. they can be a bitch to access but they do fail.
As far as the OP's problem. Could be fuel pressure related, which a gauge would tell. Or a combo or one of any other sensor on the truck nearly.
The original circled part is the Electronic spark control module, not to be confused with the pickup in the distributor. And of course the driver solenoid for the EGR valve on the backside of the same bracket.
