'85 c10
#22
Spent some time today getting the Wamrods hood struts installed. Still have to make two minor notches in the hoods but the rest is done!
Inside passenger fender
Passenger side of the hood
#27
Ordered a Circle D 278mm 3000-3200rpm stall convertor for my 80e swap! Hopefully it will be here Monday. I also ordered a TCI flexplate SFI rated. Part #399753, this one is a direct replacement for the ls1 flexplate. If you want to go with one that has the pattern for a 4l80e, then order part #399754.
I had to order this TCC switch from PSIConversion, since I wasn't aware I needed it when I ordered my harness.
